August 15, 20232 yr Hi Everyone. Please kindly assist me. I am using a Kodak Solar off grid Inverter OG 5.48, MPP range @OperatingVoltage is 120 to 450 VCD. I connected 2x550w and 1x540w in series giving me 137V and sometime above from my PV. The PV icon is flashing not charging. WhatsApp Video 2023-08-15 at 18.49.56.mp4
August 17, 20232 yr On 2023/08/16 at 2:52 AM, Cjsouls said: I am using a Kodak Solar off grid Inverter OG 5.48, MPP range @OperatingVoltage is 120 to 450 [VDC]. I connected 2x550w and 1x540w in series giving me 137V and sometime above from my PV. The PV icon is flashing not charging. Solar cells provide roughly 0.6 V with no load, and roughly 0.5 V at their maximum power point. That's in full sunlight, but the 6:5 ratio (1:0.83) roughly remains constant in usable light levels. So that means that your 137 V panels (no load) would sag to about 114 V under load. That would pull them below the low end of the MPPT voltage range. So unfortunately, three panels (even giant ones like this) aren't quite enough for your inverter's solar charger to work with. One more panel should fix the problem.
August 17, 20232 yr 23 minutes ago, Coulomb said: Solar cells provide roughly 0.6 V with no load, and roughly 0.5 V at their maximum power point. That's in full sunlight, but the 6:5 ratio (1:0.83) roughly remains constant in usable light levels. So that means that your 137 V panels (no load) would sag to about 114 V under load. That would pull them below the low end of the MPPT voltage range. So unfortunately, three panels (even giant ones like this) aren't quite enough for your inverter's solar charger to work with. One more panel should fix the problem. 100% you need another panels. We always recommend a minimum of 4 panels in series on all axpert models. The only one that is slightly better is the Axpert max 1, 7.2kva , for some reason they have a mppt controller that starts up at 90volts. up to 450volts. I love these units but most people dont go for them they want the 5kw units.
