Is RS485 pylon low voltage protocol the same for Deye & Axpert VMIII?
Greetings,
According to the manufacturer of SEG-48100H 15s 48Vdc 4.8kWh battery modules, communication with Deye hybrid inverters is possible using RS485 Pylon low voltage new protocol design 9600.
Am I right to assume that the battery can also talk to Voltronic Power Axpert inverters with "detachable" displays eg. Axpert VM III and King using the same protocol?
Edited by Kilowatt Power
  • Kilowatt Power changed the title to Is RS485 pylon low voltage protocol the same for Deye & Axpert VMIII?
The second dilemma is the battery has only 3 comm ports; RS232, CAN and RS485. How then does one connect additional batteries in parallel if the only RS485 port has been used for comms with the inverter?
For the second dilemma, the battery has 6 Ethernet ports. At least the us5000 does. I have two of them, the master is connected to Solar assistant on Console, to the Easun SV 4 (Axpert clone) on RS485and the slave is connected to master through one of the Link ports.
Example picture for the internet.
Pylontech Updates and Information
It looks to be a Seplos BMS in your battery so google that.
18 hours ago, Kilowatt Power said:
Greetings,
Yes, but the Axpert machines can only entertain the Pylon RS485. This is opposed to Deye/SS that can entertain Pylon Canbus as well.
Thanks. Shall try pairing the battery with an Axpert VM III
Upon further scrutiny of the manual, it's become clear that the 3rd or rightmost port is a combined RS485/CAN port for inverter comms. That leaves the 2nd or middle RS485 port free for battery-to-battery comms.
https://cdn.enfsolar.com/z/pp/b9pnq4usr2/SEG-48100H-4U-HESS-PRODUCT-SPECIFICATION.pdf
See page 8 items 8 (one RJ45) and 9 (2x RJ45) and page 10.
Edited by Tinbum
