KellerZa Integration Installation Video
And its working. The sensor names on the sunsynk card were sunsynk.sensor and in mqqt they were ss.sensor
Changed the name in MQQT to sunsynk and it instantly started updating :)
  • 10 months later...
  • Replies 52
  • Views 11.9k
  • Should be fixed now
  • Hi @Bobster.  No, you are not correct.  The integration works with both DEYE and Sunsynk inverters as they use the same Modbus command set.  The integration can use the Solarman Wifi Do
  • Thanks. This makes sense, and I should have expected that, because the two brands have the same hardware. Anyway, I'm still out in the cold 🙂
Hello, thank you for the video! Hoping you can help with fault finding, I'm using the solarman wifi dongle and after starting the Sunsynk add-on i get the following in the log. Any help would be much appreciated!
10:37:00 INFO Connecting to tcp://192.168.20.11:8899
10:37:00 INFO Reading startup sensors Device type, Protocol, Serial
10:37:00 ERROR Error reading: The data address received in the request is not an allowable address for the server.
I’m using an experimental dynamic tariff where low prices appear in different 15-minute periods throughout the day.
I would like to use a single slot (e.g., Prog1) to activate grid charging.
However, I can’t figure out how to set Prog1 Time so that it covers a full 24 hours (which would allow me to control Prog1 Capacity from Home Assistant whenever the price is low).
My question is:
a) How can I configure Prog1 Time to span 24 hours?
or
b) Is there a better approach to achieve this?
