September 13, 20232 yr Hi Everyone I was looking at the Modbus Protocol document for the DEYE/Sunsynk inverters yesterday and noticed some interesting registry options at the end of the register. I assume that this is for the battery packs and caters for packs 1 - 15. Would be cool to be pulling that info into Home Assistant as well 🙂
September 23, 20232 yr Author Hi Guys, In an attempt to pull data about the batteries from my inverter I added this code into my ESPhome code for my ESP32, ############### Battery Pack Data ################# - platform: modbus_controller # 600 Battery Pack 1 Voltage modbus_controller_id: sunsynk name: "deye_battery pack1 Voltage" id: sunsynk_esphome_Batt_pack1_voltage register_type: holding address: 600 unit_of_measurement: "V" accuracy_decimals: 1 device_class: voltage state_class: measurement filters: - multiply: 0.01 value_type: U_WORD - platform: modbus_controller # 601 Battery Pack 1 Current modbus_controller_id: sunsynk name: "deye battery_pack1_Current" id: sunsynk_esphome_battery_pack1_current register_type: holding address: 601 unit_of_measurement: "A" accuracy_decimals: 1 device_class: current state_class: measurement value_type: S_WORD filters: - multiply: 0.01 - platform: modbus_controller # 602 Battery Pack 1 Temperature modbus_controller_id: sunsynk name: "deye battery_pack1 Temperature" id: sunsynk_esphome_battery_pack1_temperature register_type: holding address: 602 unit_of_measurement: "°C" accuracy_decimals: 1 device_class: temperature state_class: measurement value_type: U_WORD filters: - offset: -1000 - multiply: 0.1 - platform: modbus_controller # 603 Battery Pack 1 SOC modbus_controller_id: sunsynk name: "${friendly_name} battery_pack1_SOC" id: sunsynk_esphome_battery_pack1_soc register_type: holding address: 603 unit_of_measurement: "%" accuracy_decimals: 0 device_class: battery value_type: U_WORD - platform: modbus_controller # 604 Battery Pack 1 Remaining Capacity modbus_controller_id: sunsynk name: "${friendly_name} battery_pack1_remaining_capacity" id: sunsynk_esphome_day_battery_pack1_remaining_capacity register_type: holding address: 604 unit_of_measurement: "kWh" accuracy_decimals: 1 device_class: energy state_class: total_increasing value_type: U_WORD filters: - multiply: 0.1 - platform: modbus_controller # 605 Battery Pack 1 Total Capacity modbus_controller_id: sunsynk name: "${friendly_name} battery_pack1_total_capacity" id: sunsynk_esphome_day_battery_pack1_total_capacity register_type: holding address: 605 unit_of_measurement: "kWh" accuracy_decimals: 1 device_class: energy state_class: total_increasing value_type: U_WORD filters: - multiply: 0.1 - platform: modbus_controller # 606 Battery Pack 1 Charge Voltage modbus_controller_id: sunsynk name: "${friendly_name}_battery pack1_charge_voltage" id: sunsynk_esphome_Batt_pack1_charge_voltage register_type: holding address: 606 unit_of_measurement: "V" accuracy_decimals: 1 device_class: voltage state_class: measurement filters: - multiply: 0.01 value_type: U_WORD - platform: modbus_controller # 607 Battery Pack 1 Charge Current modbus_controller_id: sunsynk name: "${friendly_name} battery_pack1_charge_Current" id: sunsynk_esphome_battery_pack1_charge_current register_type: holding address: 607 unit_of_measurement: "A" accuracy_decimals: 1 device_class: current state_class: measurement value_type: S_WORD filters: - multiply: 0.01 - platform: modbus_controller # 608 Battery Pack 1 Discharge Current modbus_controller_id: sunsynk name: "${friendly_name} battery_pack1_discharge_Current" id: sunsynk_esphome_battery_pack1_discharge_current register_type: holding address: 608 unit_of_measurement: "A" accuracy_decimals: 1 device_class: current state_class: measurement value_type: S_WORD filters: - multiply: 0.01 - platform: modbus_controller # 609 Battery Pack 1 Max Cell Voltage modbus_controller_id: sunsynk name: "${friendly_name}_battery pack1_maxcell_voltage" id: sunsynk_esphome_Batt_pack1_maxcell_voltage register_type: holding address: 609 unit_of_measurement: "V" accuracy_decimals: 1 device_class: voltage state_class: measurement filters: - multiply: 0.01 value_type: U_WORD - platform: modbus_controller # 610 Battery Pack 1 Min Cell Voltage modbus_controller_id: sunsynk name: "${friendly_name}_battery pack1_mincell_voltage" id: sunsynk_esphome_Batt_pack1_mincell_voltage register_type: holding address: 610 unit_of_measurement: "V" accuracy_decimals: 1 device_class: voltage state_class: measurement filters: - multiply: 0.01 value_type: U_WORD - platform: modbus_controller # 611 Battery Pack 1 Cycle Number modbus_controller_id: sunsynk name: "${friendly_name}_battery pack1_cycle_number" id: sunsynk_esphome_Batt_pack1_cycle_number register_type: holding address: 611 accuracy_decimals: 1 state_class: measurement value_type: U_WORD bitmask: 0x400 - platform: modbus_controller # 613 Battery Pack 1 Fault modbus_controller_id: sunsynk name: "${friendly_name}_battery pack1_fault" id: sunsynk_esphome_Batt_pack1_fault register_type: holding address: 613 accuracy_decimals: 1 state_class: measurement value_type: U_WORD bitmask: 0x400 I am getting this in the logs: [11:58:28][D][modbus_controller:032]: Modbus command to device=1 register=0x258 countdown=0 no response received - removed from send queue [11:58:29][D][modbus_controller:032]: Modbus command to device=1 register=0x265 countdown=0 no response received - removed from send queue Any suggestions? Would be cool to be able to pull some data from the inverter regarding number of cycles etc.
September 23, 20232 yr Author @kellerza Do you think we could queries these register values using your integration and see if they work?
October 5, 20232 yr I did try to get some battery data from the sunsynk at a point, but those 600 regs were empty. Have not tried recently & my ide was to rather quesry the battery directly.
December 18, 20232 yr @kellerza did you make any progress with this? Wondering if I can use the RS232 port on my Sunsynk master battery to read this information directly?
June 19, 20242 yr Did any of you ever find a solution to this question? There's a RS232 port on Sunsynk batteries which might be useful but I have no clue on how to use it, ie. I can't find any documentation on it, eg. modbus details. Nor do I know whether that information should be extracted from the inverters instead?
