Pylontech US2000Pro & US3000C FW Pack
Hi all
Can anyone point me to the FW for the above. believe there is a zip file that has the correct bin files, which then allows Batteryviewer to select the appropriate bin for the battery.
G
I updated 2000Plus and 3000C.
I have the .bin file for 2000Plus, the 3000C is a bit more tricky, the upgrade versions are different, 2 available the last time I looked. Search on the forum for differences and related file.
If you just want to connect the 2000Plus to 3000C, you only need to upgrade the 2000plus. I stacked 1x3000C, 4 x 2000 plus, 3x3000C.
Let me know if you need the 2000plus .bin. and installer.
Also remember you will need 2 different cables to connect to the console port on the battery, plus vs "C".
Hi Guys
I am about to add 5x US3000C batteries to an existing stack of 8x US3000.
As the 'C' version can address 16 batteries, and the older non-C can only address 8, I believe I need to set the Master as one of the 'C' batteries, then have batteries 2 to 8 being the non-C batteries, and the rest (9,10,11,12) can be the 'C' types. (I will then have one non-C battery spare)
All good so far ...
I also need to ensure all are of the same firmware version, so where and how do I get Batteryviewer and the Zip files ?
Thanks for any and all help
C
ps. sorry for hijacking your thread, but I thought this is relevant ....
4 hours ago, CharlieD said:
Hi Guys
All good so far ...
C
look in the downloads section.
