Solar Panel repairs
3 hours ago, Hendrik Viljoen said:
Hi.
Can anybody maybe assist and tell me which tipe of bypass diodes these panels use.
I would like to know before I take them off to test and get the correct spares.
Thanks.
I would rather try and get the specs from a top brand solar panel for the schottky diodes.
Interesting spelling from Five Star.
Hi Chris.
As long as the voltage an current ratings are higher then the specs on the panel. is that true?
I see some "bypass diodes" is a square block and if you look at the specs there is some other circuitry included in that block.
35 minutes ago, Hendrik Viljoen said:
Hi Chris.
Based on this circuit the specs for it is up to 15A which is then good for the panel with a 12A Isc.
Thanks for placing the circuit of the SM74611.
Hi Chris.
 15 Amp is also avialble. 15SQ series
15SQ SERIES N0129 REV.C (1).pdf
