November 18, 20187 yr Hi, we installed the Synerji 5KVA inverter. We installed the programmes (Power Monitor) on the laptop for the setup and connected the laptop with the USB cable to the inverter. According to the supplier, you should not switch on the innverter before you have completed the setup. But it does not pickup the inverter on Power Monitor at all. Any troubleshooting suggestions?
November 18, 20187 yr 2 hours ago, ALoock said: According to the supplier, you should not switch on the innverter before you have completed the setup. Hi ALoock, I guess what the supplier wants to say is not to switch the inverter on for operation, but you need to switch the power on to complete the setup. In short, switch the power to the unit on, complete your setup, and only after completing your setup, press the ON button for the unit to switch on its output. Only switch on the power that is needed to "power up" the unit, in most cases switching on the Battery connection should be enough.
November 18, 20187 yr Author 3 hours ago, Jaco de Jongh said: Hi ALoock, I guess what the supplier wants to say is not to switch the inverter on for operation, but you need to switch the power on to complete the setup. In short, switch the power to the unit on, complete your setup, and only after completing your setup, press the ON button for the unit to switch on its output. Only switch on the power that is needed to "power up" the unit, in most cases switching on the Battery connection should be enough. Hi Jaco, thank you for your reply. We also thought so but was affraid to do it before getting any feedback. We have switched the power on at the unit, but still don’t pick it up. We rechecked all the input and output cables, all is 100%. Think the inverter is faulty.
November 18, 20187 yr 1 hour ago, ALoock said: We rechecked all the input and output cables, all is 100% What cable do you use for communication? Are you sure the correct drivers were loaded for your Operating System.
November 20, 20187 yr On 2018/11/18 at 5:55 AM, ALoock said: Hi, we installed the Synerji 5KVA inverter. We installed the programmes (Power Monitor) on the laptop for the setup and connected the laptop with the USB cable to the inverter. According to the supplier, you should not switch on the innverter before you have completed the setup. But it does not pickup the inverter on Power Monitor at all. Any troubleshooting suggestions? Did you use the cable supplied with the inverter?
November 20, 20187 yr Did you install this software? Software: RS485-Software-for-EP18-PV18-PH18-PH30-PV35-Wincc-2.0.30&Ch340tDrver.7z Download Software: Usb-to-Rs485-Driver.zip Download
November 20, 20187 yr It seems your inverter is a rebranded of this: https://www.mustpower.com/pv1800-hm-series-high-frequency-off-grid-solar-inverter-2-5kva/
January 23, 20197 yr I have purchased 3 x 5kW “ Synerji “ inverters I also purchased 3 communication cards with cable to support 3 phase equipment The system is running very well and I am very happy. BUT I cannot monitor my output / production as the software I got with the inverters do not connect with pc / laptop I have tried but all failed .
September 16, 20214 yr On 2018/11/20 at 11:45 AM, Gabriel_2018 said: Did you install this software? Software: RS485-Software-for-EP18-PV18-PH18-PH30-PV35-Wincc-2.0.30&Ch340tDrver.7z Download Software: Usb-to-Rs485-Driver.zip Download Hello please can u give me the software ,, because the software on the website is deleted , the link won't open thank you
April 12, 20224 yr On 2021/09/16 at 10:29 AM, hosam_sy said: Hello please can u give me the software ,, because the software on the website is deleted , the link won't open thank you I'm also trying to get this software but the link does not work. Anyone have an alternative please?
April 13, 20224 yr On 2019/01/23 at 9:58 AM, EugeneF said: I have purchased 3 x 5kW “ Synerji “ inverters I also purchased 3 communication cards with cable to support 3 phase equipment The system is running very well and I am very happy. BUT I cannot monitor my output / production as the software I got with the inverters do not connect with pc / laptop I have tried but all failed . Did you manage to get monitoring going with any software?
August 3, 20223 yr Good day, We have synerji inverter and suddenly it's off. Pressing "on" button doesn't do anything. Not sure what to do, how do I swith it back on?
