Axpert 5KVA - acting up
I've just lost my solar virginity couple of weeks back, small setup for play and learning purposes. 3 x 265 AE pannels, 1 x Aexpert 5KVA, 1x US2000 Pylontech.
Using ICC to monitor and configure an inverter, also monitoring battery with the custom us2000 cable for icc software.
The last couple of days I've noticed that Axpert simply stopped using PV input. It shows a mppt reading of ~100 V but it's not using any of it.
Not sure if I got some settings mixed up, or there is something else going on. But only way to get pv to be used is to "reboot" inverter.
Any ideas ?
So even weirder is that this morning it produced for a short while and than off ....
Must be a setting is selected wrong?
I've seen once how a bug in mppt firmware could cause it to get stuck in startup. It was an mppt from a different manufacturer, so this might not be applicable, but it does happen. Changing settings, such as charge voltage, might sometimes reset the algorithm and cause it to start up. This is of course not a long term solution, just a test.
26 minutes ago, plonkster said:
I've seen once how a bug in mppt firmware could cause it to get stuck in startup. It was an mppt from a different manufacturer, so this might not be applicable, but it does happen. Changing settings, such as charge voltage, might sometimes reset the algorithm and cause it to start up. I is of course not a long term solution, just a test.
6
I'll add that to a list of things to try before my "nuclear" option of rebooting.
What are the recommended resources to check firmware updates and known issues?
It's one of the things that continues to amaze me about this inverter, how it remains so popular despite the really shoddy firmware situation. I know this is not an answer... Other than our resident Aussies I know no resources.
The PIP-4048MS and PIP-5048MS inverters topic at the Australian Electric Vehicle Association.
Cheeeeeap! :-)  I mean, inexpensive.
Plus the hope that one day, the firmware issues will be resolved by the manufacturer. Surely. Even though it's been over five years. And then, they'll be reasonable inverter-chargers. Not great, but good enough for many purposes.
Priceless resource master Obi Van!!
As it turned out my firmware is 72.70c. Which according to the resource above is one of yours master.
Not clear what actual hardware it is [ill assume its some genuine Axpert MKS II for now], as barcodes and other insignias on the box are possibly some South African rebrand, so they must have flushed before shipping.
Indeed, low bar entry to slide into the new ear of the solar [r]evolution.
10 hours ago, plonkster said:
... how it remains so popular ...
I've been thinking about that lately.
Voltronic makes a lot of sense for the DIY'er, tinkerers, sorting a problem quickly and very cost effectively ... sliding into a new era of the solar [r]evolution.
However. The moment you are not a DIY'er, tinkerer, you cannot be bothered with issues or forums, you have it done professionally, then the picture changes very quickly.
The above two groups shall never meet. :-)
Ps. I do have a tickle to get an idea to form a thought to wonder if maybe the Victron group is every so slightly growing her on PF. ;-)
Actually, it will likely be an Axpert MKS (not MKS II). The II indicates 450 V MPPT.
Any way to confirm this without popping the lid and scanning chipset serial numbers?
Just the usual genuineness hints, as on my Can I update my firmware? post: [ edit: you should now use Do I Own a Clone? . ]
  • A label on the side with a bar-code
  • 14-digit bar-code number, starting with 9293, next 4 digits are manufacturing date YYMM, next digit a "1"
  • Small sticker with manufacturing year and 12 parts, with a month blacked out, covering the screw nearest the large label with bar-code
  • The font should "look right"; you'd have to compare with other labels on the internet. But if you've passed the tests above, it's pretty conclusive.
If yours in genuine, then it will be an Axpert MKS, based on the fact that you are running patched firmware version 72.70c successfully. As a point of interest, it didn't come out of the box with that patched firmware, did it? That would really make my day :D
"Do I Own a Clone" link.
I've poured over the wealth of accumulated knowledge on your forum. Strange thing is, that those barcode descriptions and markings dont match pretty much anything on my unit. So i assumed it was some ZA local distributor that branded this unit, including different barcodes etc.
Yes, master Obi Van, it came straight out of the box like it is on my wall now, firmware and all!
It's not strange if it is a clone. @Padwan sent me a PM with a photo of his label and LC Display. The label looks non-genuine, but the display and buttons are perfect.
@malek94 posted that when a reseller buys a container worth of machines, they get the option of a custom label / sticker. So a genuine machine's label might not conform to the Voltronic default 14-digit bar-code; it seems likely that they would want to change that. So that makes it really hard to pick a clone.
https://powerforum.co.za/topic/2325-axpert-5kva-firmware/?do=findComment&comment=37851
Quote
The label is put on by the manufacturer, not the reseller (though the reseller might add another sticker). But as per the above, the manufacturer could provide a custom label anyway.
I have the same problem, (3 x 5kv inverters in parallel Not the latest models) the inverters were running on grid power through the night no problem the system is set to switch on at 07h15 to solar power, as soon as it did this the system crashed and gave me an error code 60 but only on inverters 1 and 3 Code 60 states that there is feed back power. How can this just happen when the system was running fine with no issues? Any suggestions
