March 11, 20215 yr Press and hold the on/off button for about 15 seconds. Puts it into program mode... then press and hold again for about 15 seconds, takes it out of program mode and alarms should be reset.
March 10, 20233 yr Hi I’m trying to connect Huawei 48100 battery to growatt spf5000es but inverter not identifying the battery can some help me with diagram or can some one send me a tool to read battery parameters from pc directly from battery
April 9, 20233 yr Hi everybody Can someone guide me how to connect Huawei ESM 48100b1 with laptop. I need to change the charge coefficient from 0.15C to 0.5C. Should I need to make485 cablefirst and connect using 422/485 converter.Plzguidein this regard.Also plzmention where to locate this Enspire software through which i can connect the storage module. Iwant to connect the ESM 48100AH with my solar inverter.Waiting foryoureply Regards Mubbashir
February 20, 20242 yr On 2023/04/10 at 12:10 AM, mubbashir.ihsan said: Hi everybody Can someone guide me how to connect Huawei ESM 48100b1 with laptop. I need to change the charge coefficient from 0.15C to 0.5C. Should I need to make485 cablefirst and connect using 422/485 converter.Plzguidein this regard.Also plzmention where to locate this Enspire software through which i can connect the storage module. Iwant to connect the ESM 48100AH with my solar inverter.Waiting foryoureply Regards Mubbashir Here is some c# proof of concept/sample code for connecting to the ESM batteries over RS485: https://github.com/TruthData/SimpleModbusCommander notice Device ID's for all these bats seem to be hardcoded to 214, and they are stubborn when establishing the first connection. More info is here:
May 22, 20242 yr Hi There, is it possible to connect the ESM-48100A1 to Sunsynk? I tried the following can cable configuration but no luck.... Battery Side: Pin 7 Can H, Pin 8, Can L Inverter Side: Pin 4 Can H, Pin 5 Can L,
April 9Apr 9 DearsHow I can reset the Huawei Lion Battery ESM48100, by the way I have a software "batterymodbustool" and I can connect to the battery with an adapter and minitor voltage, temp, alarms .. etc but I can't change anything. Can anyone send me a tool to enable me changing parameters and reset the alarms?Many thanks
