February 25, 20242 yr Hi everyone. A short while back, after a typical JHB afternoon thunderstorm, 3 of my 4 Narada batteries stopped reporting SOC to solar assistant (and one of my two Axperts died as well). After some digging I found the supposedly official Narada BMS software and checked each battery to confirm what was going on. I get a "no communication" message on each of the three suspected broken units. The 4th reports data as per solar assistant. So I assume the BMS got fried in the storm? Is such a thing repairable and if so, by whom? Thanks
February 25, 20242 yr 9 hours ago, miles said: Hi everyone. A short while back, after a typical JHB afternoon thunderstorm, 3 of my 4 Narada batteries stopped reporting SOC to solar assistant (and one of my two Axperts died as well). After some digging I found the supposedly official Narada BMS software and checked each battery to confirm what was going on. I get a "no communication" message on each of the three suspected broken units. The 4th reports data as per solar assistant. So I assume the BMS got fried in the storm? Is such a thing repairable and if so, by whom? Thanks Start asking the guys that repair inverters if they do it or if they can recommend someone.
February 25, 20242 yr Same thing happened to my Narada's a few years ago. 3 of them knocked out by a lightning strike. I replaced the bms with Ant and JBD. Of the two, the JBD is definitely the better one. All the batteries are still running with no problems. Edited February 25, 20242 yr by GVC
February 27, 20242 yr Author On 2024/02/25 at 8:09 PM, GVC said: Same thing happened to my Narada's a few years ago. 3 of them knocked out by a lightning strike. I replaced the bms with Ant and JBD. Of the two, the JBD is definitely the better one. All the batteries are still running with no problems. I had a quick look at what Ant and JBD are. Looks quite complicated from an installation/setup point of view?
February 27, 20242 yr 1 hour ago, miles said: I had a quick look at what Ant and JBD are. Looks quite complicated from an installation/setup point of view? Then there js also the JK. Look at the Off grid garage videos on them on YouTube. Also a number of members here are using them. Me included.
February 28, 20242 yr Author On 2024/02/25 at 8:09 PM, GVC said: Same thing happened to my Narada's a few years ago. 3 of them knocked out by a lightning strike. I replaced the bms with Ant and JBD. Of the two, the JBD is definitely the better one. All the batteries are still running with no problems. Any chance you have a picture of your setup?
February 28, 20242 yr 6 minutes ago, miles said: Any chance you have a picture of your setup? No but just Google. Mine is inside a battery box with my 2 banks. Inverter is on top and have to disconnect battery and PV to get access. There are some variations like some have a switch to switch on and others via the APP only. Others take 8-20 cells and installed one with up to 24 cells.
