Hi all, just looking for some recommendations please.
I have an additional surface mount DB which will house everything for an inverter installation (will be replaced with bigger one and surge arrestors, etc).
The thing is, I want to get the wires from the existing DB to the new one through the back (the way it should be), but as you can see there is existing conduit running upwards in the wall cavity (brick wall). I can only mount it above the old one, no space to the sides.
Does anyone have some recommendations on how to do this in the easiest manner and still provide double insulation for the wires? I cannot remove the old flush mount DB as it is really stuck and the conduit will slip out.
Was thinking to drill a hole sideways at the back of the old DB and then also a hole through the wall of the surface mount one, and then somehow try and get a piece of sprague to join the two.
How would the professionals do this with the least amount of effort, and mess?
Question
Qtin
Thanks in advance
Link to comment
Share on other sites
11 answers to this question
