February 15, 20197 yr So i cam across a battery at a client that was given to them for disposal as it only has 80% capacity left apparently. It is marked as a KION Batterie Lithium Ion B2, Nominal voltage 23.1v and 410Ah and was manufactured on 16/11/2016. Anyone know if this would work on a 24v solar system?
February 15, 20197 yr This looks like a battery that comes out of a forklift. Linde is the forklift make/model. https://www.linde-mh.com/en/About-us/Innovations-from-Linde/Lithium-Ionen.html I cant find any spec sheets, but the url above gives some info. One would think it should be fine to use in a normal 24v solar system, but hey ... i'm a noob in this forum, so please check with some others first Edited February 15, 20197 yr by stoic
