Morena Posted April 18 Share Posted April 18 Are aluminum rails better than galvanised and which reputable service providers can I use for buying? I have 16 panels that need to be installed and I stay in Johannesburg. Quote Link to comment Share on other sites More sharing options...
TaliaB Posted April 18 Share Posted April 18 1 hour ago, Morena said: Are aluminum rails better than galvanised and which reputable service providers can I use for buying? I have 16 panels that need to be installed and I stay in Johannesburg. Aluminum weighs much less than galvanized steel and does not rust. Renusol or Photon is a good solid design. Contact Herholdts Group Jhb. https://herholdts.co.za/ps536/mounting-structures/ Derek3 1 Quote Link to comment Share on other sites More sharing options...
Morena Posted April 19 Author Share Posted April 19 5 hours ago, TaliaB said: Aluminum weighs much less than galvanized steel and does not rust. Renusol or Photon is a good solid design. Contact Herholdts Group Jhb. https://herholdts.co.za/ps536/mounting-structures/ Thank you very much. I'm now definitely going for aluminum. Quote Link to comment Share on other sites More sharing options...
AntonS Posted April 19 Share Posted April 19 You can also try KD Solar http://www.kdsolar.co.za local manufacturer. I have them on my roof. Easy to install. Quote Link to comment Share on other sites More sharing options...
AndrewJdc Posted April 19 Share Posted April 19 In jhb youll probably get away with galvanized steel but not cape town. Aluminum is light weight but expensive compared to steel. I think in your case (mounting 16 panels), steel might be a cheaper option in the short term. But i would go for aluminum if cost is not a consideration. Quote Link to comment Share on other sites More sharing options...
Morena Posted April 26 Author Share Posted April 26 On 2024/04/19 at 9:59 AM, AntonS said: You can also try KD Solar http://www.kdsolar.co.za local manufacturer. I have them on my roof. Easy to install. Thank you very much. I will be ordering the things that I couldn't find at Herholdts from KD Solar. AntonS 1 Quote Link to comment Share on other sites More sharing options...
