May 1, 20242 yr Hi I replaced axpert inverter with Deye 5kva inverter, everything is setup but I don't no how to easily override set parameters if I want to go whenever I want to grid charge due to LS or bad weather, Axpert was only on app or program 01 select SOL and was sorted, is there a shortcut on Deye for easy change-over?
May 1, 20242 yr Un-tick/de-activate the Time of Use settings under the Work Mode screen, and make sue the Grid-Charge block is ticked under the Battery Settings screen. Should do the job, but not sure I'd call it a shortcut.
May 1, 20242 yr Some settings on work mode: The Batt settings determine the SOC and will influence the charge requirements. When the PV is abundant, the inverter will automatically negate the GRID/GEN charge instructions. If you de-activate the TOU setting, you loose the management functionality.
May 1, 20242 yr Author 6 minutes ago, CobusK said: Check the Battery settings as well. Thank you, appreciate it, will play around with it
