July 31, 20242 yr I was wondering in diffrent regions of SA those with monotoring software, what is the maximum time that Imp max value was observed from your SCC and for how long? I have seen on my own istallations during summer with clouds that Imp will spike to nameplate rating for 5~30 seconds. Is there anyone that has experienced longer periods. I am specifically interested in the maximum current in series strings and strings in parallel. If you could be so kind to state your Province, Solar panel manufacturer and Power rating and also SCC( or inverter manufacturer and specifications) and lastly load connected and battery Soc when observation was made. Many thanks.
July 31, 20242 yr 7 hours ago, TaliaB said: I was wondering in diffrent regions of SA those with monotoring software, what is the maximum time that Imp max value was observed from your SCC and for how long? I have seen on my own istallations during summer with clouds that Imp will spike to nameplate rating for 5~30 seconds. Is there anyone that has experienced longer periods. I am specifically interested in the maximum current in series strings and strings in parallel. If you could be so kind to state your Province, Solar panel manufacturer and Power rating and also SCC( or inverter manufacturer and specifications) and lastly load connected and battery Soc when observation was made. Many thanks. I will send you info on your request give me a few days.
August 1, 20242 yr Here goes: (added at bit more info for context) Wattage Recorded: 9018W Imp: 16.1A & 13.5A Imp Ratio: 16.1/18.36 = 87.7% Date & Time: 30 July 2024 @ 10:53:44 Duration: 108s Max. Normal Production: 7484W (31 July 2024) PV last cleaned: 16 July 2024 Province: Gauteng PV Manufacturer: Canadian Solar Power Rating: 32 x 365W = 11680W PV Composition/Orientation: 8S2P - North, 8S2P - West System: Sunsynk 8.8kW Load: 3044W Battery SOC%: 69% Edited August 1, 20242 yr by Sidewinder Added Imp values
August 1, 20242 yr 2 hours ago, Sidewinder said: Here goes: (added at bit more info for context) Wattage Recorded: 9018W Imp: 16.1A & 13.5A Date & Time: 30 July 2024 @ 10:53:44 Max. Normal Production: 7484W (31 July 2024) PV last cleaned: 16 July 2024 Province: Gauteng PV Manufacturer: Canadian Solar Power Rating: 32 x 365W = 11680W PV Composition/Orientation: 8S2P - North, 8S2P - West System: Sunsynk 8.8kW Load: 3044W Battery SOC%: 69% Great information but is the question not around producing at a Imp level or higher and for how long? This I read if your system got to 11680W or higher
August 1, 20242 yr Author 4 hours ago, Sidewinder said: Here goes: (added at bit more info for context) Wattage Recorded: 9018W Imp: 16.1A & 13.5A Date & Time: 30 July 2024 @ 10:53:44 Max. Normal Production: 7484W (31 July 2024) PV last cleaned: 16 July 2024 Province: Gauteng PV Manufacturer: Canadian Solar Power Rating: 32 x 365W = 11680W PV Composition/Orientation: 8S2P - North, 8S2P - West System: Sunsynk 8.8kW Load: 3044W Battery SOC%: 69% Thanks @Sidewinderfor the information i see the North Imp= 16.1A -Imp 18.36 A.( 365w Canadian2p) = 2.26A before reaching IMP. Not bad going for this time of the year but seems Jozi was pushing the solar as of late but can't say the same for Western Cape this year's winter was a disaster in more than one way.
August 1, 20242 yr Thanks @TaliaB & @Scorp007, updated my stats with duration and Imp ratio (made sense to me)
August 1, 20242 yr @TaliaB The best that I can provide is the following. Not having more detail. Imp=8.71A 285W Solis 4G grid tied on 28/7. Series string of 6. Peak current 7.1A midday. Not seen anything close to Imp this month. Will have to wait quite a bit longer for higher irradiation. Edited August 1, 20242 yr by Scorp007
August 1, 20242 yr @TaliaB From December 2023 to show some clipping. KZN Midlands Canadian Solar 415W Imp = 10.56A Isc = 11.14A Vmp = 39.3V Voc = 47.8V MPPT2:- P2S6 (12 panels) = 4980W, Voc 286.8V, Vmp 235.8V Total Facing 25 Deg NE ( N=0 Deg, E=90 Deg, S=180 Deg, W=270 Deg), Elevation tiled roof +- 22 Deg. SunSynk 8.8 kW +- 2021, never upgraded Firmware. Edited August 1, 20242 yr by TimCam
August 1, 20242 yr Author 1 hour ago, TimCam said: @TaliaB From December 2023 to show some clipping. KZN Midlands Canadian Solar 415W Imp = 10.56A Isc = 11.14A Vmp = 39.3V Voc = 47.8V MPPT2:- P2S6 (12 panels) = 4980W, Voc 286.8V, Vmp 235.8V Total Facing 25 Deg NE ( N=0 Deg, E=90 Deg, S=180 Deg, W=270 Deg), Elevation tiled roof +- 22 Deg. SunSynk 8.8 kW +- 2021, never upgraded Firmware. Thanks @TimCamthat is very efficient production 95% of Imp but 77% of Mppt max current input. At 07h00 you are on Vmp max with very little current flowing whereas it starts to drops at around 07h30 when current starts to flow. Very good data thanks again. Edited August 1, 20242 yr by TaliaB Correction on calculation
August 1, 20242 yr Unfortunately the old SunSynk 8.8 kW could only process between 18 - 20A per MPPT, mine is one of those, so no 26A for me, therefor the clipping at 19.8A. 😢
August 2, 20242 yr Author 9 hours ago, TimCam said: Unfortunately the old SunSynk 8.8 kW could only process between 18 - 20A per MPPT, mine is one of those, so no 26A for me, therefor the clipping at 19.8A. 😢 Ah ok not the end of the world you only loosing 5% at peak production. For future expansion you can always up the voltage by adding panels in series to each string.
