DC Disconnect Switch
Good day i would be happy if anyone can point me in the right direction. I am thinking of getting additional lifePo4 batteries but different brand also different BMS can i use a DC Disconnect switch to move from one set of batteries to the other and how do i connect it if possible thank you in advance forgot to mention i have an Axpert 7.5 inverter .
Edited by kifo
I may be wrong here, but what I have read is that it would be best to connect each battery to a common busbar(parallel) through a fuse for each battery, then through a "main" fuse to the inverter, you can then control this either using a smart shunt or voltages from the inverter.
Just my 2c
Remember i am looking to just switch between two different types of lithium battery one is complete wall battery 48v 100ah and other batteries i want to add to my system is 8 12v 100ah where i would put for each inseries and parallel them which owuld make that side 48v 200ah , then i would like to know if i can connect the dc dsiconnect switch to move form set of battery to other thanks.
You can but ....
- no problem when you switch OFF one set of batteries
- high current flow between sets of batteries if ever you switch one set previously OFF to ON and both set are not exactly at the same voltage when you switch one back ON. Most BMS will consider the high current flow as a short circuit then may turn OFF
Any reason you would want to have a disconnect for each set ?
May be the correct question is i have one of those 48v wall battery @ 100ah and i am getting 8 12v 100ah i want yo add to my sytem with a  48v hybrid invert rated at 7500w thanks just wondering how to connect all batteries with inverter.
One option among others :
Use a busbar with 1 DC switch / MCB / MCCB to disconnect all batteries.
Before connecting the batteries, charge them 1 by 1 to a close voltage to avoid large amount of energy transfer when you finally connect them ...
First of all ensure that the 48v wall mount battery is 16 cells and not 15 cell. Then ensure all battery cells are Lifepo4 and not diffrent lithuim chemistries like for eg. NMC.
To prepare the 8 x 12v batteries you need to ensure that before connecting them in series they all need to be at the same SOC. To accomplish that connect all 8 in parallel ( 12v 800ah) and charge them to 100% SOC and keep them connected in parallel for 24 hours after charger has been removed.
Connect the 8 x 12v batteries according to the diagram below and incorporate 2 x battery balancers to the 2 string battery connection from there parallel the wall mount with thev12v bank.
final-configuration-for-8-12V-batteries-making-a-48v-battery.webp.3d655872130081a68df803ff0204b043.webp
Also the battery balancers for the 2 series strings.
lithium-48v-battery-balancer-equaliser-with-led-suitable-for-all-battery-types-24v-36v-or-48v-2-4x-12v-batteries.thumb.jpg.d552b685bc9c09a26281887760feb290.jpg
Ok i am changing configuration will be using four 24v lifepo4 200ah instead what balance should i get for those thanks.
If I read it correctly you will be using 2 x 24V lifepo4 in series to get 48V and then another 2 in series which you parallel with the 1st 2?
