March 22, 20197 yr Is that a solar battery? "HRL 12390W is specially designed for high efficient discharge application. Its characteristics are high energy density, small footprint and high discharge efficiency. It can be used for more than 260 cycles at 100% discharge in cycle service, up to 10 years standby" I'm not sure that is the right application. For standby maybe, but not for frequent use. Edited March 22, 20197 yr by DeepBass9
March 22, 20197 yr As I see it, these are your options. 1. Trojan flooded lead acid. Needs to be watered. Typically 1600 cycles at 50% DoD. The typical starter kit would be 8 x T105RE, and it's going to set you back 20k to 25k. 2. A good AGM battery. Trojan makes some. Victron does. Ritar too (I think). Around 1200 cycles at 50% DoD. It's going to set you back 16k or more. 3. Lithium Iron Phosphate battery. Significantly more cycle life, significantly higher price too, best price per stored unit. The cycle life is pretty much the most important part.
March 22, 20197 yr 24 minutes ago, plonkster said: Trojan makes some. ... Around 1200 cycles 1700 cycles.
