What percentage for cutoff with 48V system?
Hi.
I'm getting confused here with some basic maths but then I also don't understand the question.
On my inverter with a HINA ESS Hi-5 battery, I need to set the cutoff voltage but as a percentage.
According to the sticker on the side, suggested cutoff voltage is 49-50V. The inverter asks for a percentage. Is it percentage used or percentage left.
Please help me with the correct value for 49V as a percentage.
Thanks.
Deon
Inverter low DC cut off % is set by some 15 % and otheres 20% when it comes to volts this will depend on amount cells and cell chemistry of cell .
If you using com cable then % is used I'd you not then volts like I say will depend on the battery .
2 hours ago, deonholt said:
Hi.
Thanks.
Deon
The manual provides the answer. 49-50V is at 20%.
