January 1, 20251 yr Dear readers, My Voltronic inverter equipment decided to stop working after 7 years. The charger part, without switching on button, still works, but once I switch-on the power button, and try to invert the current, starts the alarm with error code 09. Initially, when the equipment abruptly stopped with weak load, I could read the 05 error code before shut down. I disconnected AC out wires and measured the voltage, however, it does not provide any volt while alarm is signing. I opened the inverter and I could not see any burnt part. Can you suggest any other part I should check before buy another equipment? :-/ Thanks so much in advance for your help.
January 1, 20251 yr 50 minutes ago, 4ldesign said: Dear readers, My Voltronic inverter equipment decided to stop working after 7 years. The charger part, without switching on button, still works, but once I switch-on the power button, and try to invert the current, starts the alarm with error code 09. Initially, when the equipment abruptly stopped with weak load, I could read the 05 error code before shut down. I disconnected AC out wires and measured the voltage, however, it does not provide any volt while alarm is signing. I opened the inverter and I could not see any burnt part. Can you suggest any other part I should check before buy another equipment? ๐ Thanks so much in advance for your help. Error 05 is output short circuit and 09 bus soft start failed.ย You have had great service out of the inverter ๐ This is one for @BritishRacingGreenย or @Coulomb
January 2, 20251 yr 10 hours ago, 4ldesign said: I opened the inverter and I could not see any burnt part. The MOSFETs in these models run right along the side, hidden under an overhang. That's where you usually see the worst carnage. In this case, you should also check the IGBTs on the middle heatsink. Sometimes the damage is fairly subtle, like a crack in the epoxy.ย Unless you are handy with electronics, fir example you have access to a desoldering station, it's probably time to retire this inverter.ย
January 2, 20251 yr Author You are always so helpful! I will buy now another equipment, and eventually, with more time I would check everything you have mentioned. Always good to have a spare inverter if I could fix it. Thanks again!
