DIY combiner box help needed
Hi ppl
I replaced old panels with  new 555w Canadians now and need a new combiner box. MY idea is to use 20A circuit brakers instead the old fusers as MCB.s are more convenient to use . Can some one help me with the box design  please. I have two Kodak 4kw inverters, 12 X555 solar panels ( 8 facing east 4 facing west) and 5X3500 Pylontech batteries.
Any suggestion will be appreciated.
cheers
Edited by ibiza
thank you so much for your advice Haudevde, it is very valuable . I almost completed wiring
This is how it looks now
Edited by ibiza
@ibiza ,
The photo you've posted gets a bit blurred when one zoom's in.
The following comes to mind:
1) The Isolators seem to be AC ones. You should not mix AC & DC.
2) To terminate cables, one should use ferrules.
3) Fuses. Please include those as well (or are they located in another DB)
4) Same with SPD's.
General: The DB seems too small to house a 6 into 2 PV system. - Unless you have the real protection elsewhere.
Here is what a typical 2 into 1 PV system could look like.WhatsApp Image 2025-04-04 at 16.18.38_afe3b93c.jpg
Edited by Sidewinder
