PV panels.
38 minutes ago, Herbie. said:
Got enough space
Without voltage and amp rating of the panel, and brand of inverter, it's impossible to say.
The inverter dictates the max voltage, and amp input. When all else is the same, go for 455 since it gives around 150w more.
Edit: seems you are using kodak og, so stick withing these params, since the panel specs are unknown to us.
MPPT Range @ Operating Voltage : 120 VDC ~ 380 VDC
Maximum PV Array Open Circuit Voltage : 500 VDC
MPPT Maximum Input Current : 18 A
Max IC : 18 A
Max lsc : 22 A
Edited by Pho3niX90
Okay, so your best bet with these panels and inverter, if it's a choice between just these options, and if it's the typical Voc=50V-odd, then take 8x550W, but connect them all in series, ie. 8s, not 4s2p.
It begs the question of whether you could do better with a different panel altogether, that has a higher Imp closer to 16-17A, so you could connect 5000W of panels more easily.
Right now the Voltage is your limiting factor in a series string, and the current if you're thinking to go parallel.
Edited by GreenFields
