May 18, 20251 yr I have an issue where the battery goes from 50% to 10% in about 10 minutes when I use it. 468 cycles. I sent it in for repair, and they said they just needed to rebalance it.My other two batteries have a difference of 0.01V between the highest and lowest cells, but this battery has a difference of 0.15V.From my reading, this big a difference in V between the cells is a problem and points to problems. What is my recourse? Do I send it in again for rebalancing, or can I dictate that they either fix it by replacing the cells or that they replace it with a battery with the same cycle count? How do I enforce the 10-year warranty?Has anyone had issues with a sunsynk battery that they had to replace?Just FYI the last rebalance took 5 months for me to get it back.
May 18, 20251 yr Hi There,Is it not a function of the BMS to keep the cells in balance?How are you reading the cell voltages?5 months to get your battery returned......you must be kidding !!!Contact Keith Gough directly.......
May 18, 20251 yr Author Solarassistant gives more details about your battery. So it show cell voltage
May 18, 20251 yr I had a similar issue with my newest purchased Leoch 48100-S pack. From the beginning cell 15 showed significantly higher voltage at charge and lower at discharge. This being a brand-new pack I contacted the official importer and seller, Averge, with a guarantee claim. But they didn't want to do anything about it. I asked to allow me to open the pack without voiding the guarantee to check the cells connections. They wrote me the permission and so I did. I tightened all M4 hexagon bolts of the cell bridges with a socket wrench. Some allowed up to a half turn. After reassembly and re-connection the issue with cell 15 no longer persists. It looks like all cells run the same voltage within a few mV. This proves to me that all cells are in good health.
May 18, 20251 yr As @Beat mentioned, most of these issues typically are related to loose connections, or balancing issues. Since it was already rebalanced, it's probably a loose connection. A good way to diagnose it, is if the lowest cell is always consistently the same when top balancing it, or when reaching a full charge. This is mainly why I can never get behind off the shelve batteries. Fixing a simple issues voids your warranty, and retightening the nuts is a maintenance item.
May 19, 20251 yr 13 hours ago, rterblanche said:Solarassistant gives more details about your battery. So it show cell voltageIt shows 3 values only, Highest, Lowest and Average for all cells.It does not show which cell either unfortunately
