June 5, 20251 yr I stay in Cape Town and want to position the 6 panels each on my 2 strings to get optimal performance. They are on a flat roofI which direction should they be facing and at what pitch installed? Edited June 5, 20251 yr by AndreGreyling
June 5, 20251 yr Install 6 panels in direction 45 degrees, pitch 30 degrees. Install the other 6 panels in direction 315 degrees also at pitch 30 degrees.
June 5, 20251 yr If you decide to install 6 panels NE and 6 panels NW as suggested by @frivan ensure that each string of 6 panels is connected to separate Mppt's to avoid mismatch losses. Also on a flat roof at 30 degree tilt i will use Bifacial solar panels to capture reflected light from the roof,clouds and walls which can help in morning, late afternoon, or overcast days.
June 6, 20251 yr Author 22 hours ago, TaliaB said:If you decide to install 6 panels NE and 6 panels NW as suggested by @frivan ensure that each string of 6 panels is connected to separate Mppt's to avoid mismatch losses.Also on a flat roof at 30 degree tilt i will use Bifacial solar panels to capture reflected light from the roof,clouds and walls which can help in morning, late afternoon, or overcast days.ThanksIf I pitch the panels north on a flat roof what degrees is best for winter in Cape Town?
June 6, 20251 yr 41 minutes ago, AndreGreyling said:ThanksIf I pitch the panels north on a flat roof what degrees is best for winter in Cape Town?Cape Town Latitude: Approximately 34 deg South. Best Tilt Angle for Winter (North-facing panels in Cape Town) Winter-optimal tilt = latitude + 10 deg to 15 deg So: 34 deg + 10 deg to 15 deg = 44 deg to 49 deg.
June 6, 20251 yr Use a PV calculator, such as https://pvgis.com/enYou can then play "what if" scenarios in terms of pitch angle AND azimuth, and see the difference of these for summer or winter optimisation (quite large differences...).Good luck with your design and PV system 🙂
June 6, 20251 yr Author 14 minutes ago, TaliaB said:Cape Town Latitude: Approximately 34 deg South. Best Tilt Angle for Winter (North-facing panels in Cape Town) Winter-optimal tilt = latitude + 10 deg to 15 deg So: 34 deg + 10 deg to 15 deg = 44 deg to 49 deg.Thanks for info!
June 6, 20251 yr Author 1 minute ago, HennieL said:Use a PV calculator, such as https://pvgis.com/enYou can then play "what if" scenarios in terms of pitch angle AND azimuth, and see the difference of these for summer or winter optimisation (quite large differences...).Good luck with your design and PV system 🙂Thanks Hennie!
June 6, 20251 yr Of course, it's not just pitch angle and azimuth - even more important is to ensure the panels are never exposed to shadows from surrounding trees, buildings, etc.
June 6, 20251 yr 23 minutes ago, AndreGreyling said:Thanks for info!24 minutes ago, HennieL said:You can then play "what if" scenarios in terms of pitch angle AND azimuth, and see the difference of these for summer or winter optimisation (quite large differences...).30 deg year-round average 34 deg Latitude (annual optimum) Balanced yearly performance45–50 deg winter-focused maximizes winter yield, reduces summer peak slightly15–20 deg summer-focused more energy in summer, less in winter
