June 15, 20251 yr Morningtoday my 10kw sunysynk battery is showing these lights, I tried to turn it on and off and and to reset but no getting it right. my configurations are as follows:16kw sunsynk inverterEast facing panels = 4kwwest facing panels = 4 kwnorth facing panels = 6 kw10kw sunsynk battery , BMS settings are capacity 208h, charging 60A, discharging Amps 100Hope the battery is still okay
June 15, 20251 yr 1 hour ago, bafana said:Morningtoday my 10kw sunysynk battery is showing these lights, I tried to turn it on and off and and to reset but no getting it right. my configurations are as follows:16kw sunsynk inverterEast facing panels = 4kwwest facing panels = 4 kwnorth facing panels = 6 kw10kw sunsynk battery , BMS settings are capacity 208h, charging 60A, discharging Amps 100Hope the battery is still okayDo you have access to cell voltages and BMS data?If you do, post them here. Otherwise not really possible to accurately troubleshoot
June 15, 20251 yr 2 hours ago, bafana said:Morningtoday my 10kw sunysynk battery is showing these lights, I tried to turn it on and off and and to reset but no getting it right. my configurations are as follows:16kw sunsynk inverterEast facing panels = 4kwwest facing panels = 4 kwnorth facing panels = 6 kw10kw sunsynk battery , BMS settings are capacity 208h, charging 60A, discharging Amps 100Hope the battery is still okayALM (Alarm) - Red Light OnThis means the battery has detected a fault or protection condition. The cause could be one of the following: Overvoltage or undervoltage. Overcurrent during charge/discharge. Overtemperature. Cell imbalance. Communication error with inverter or BMS.RUN LED - OFFNormally this should be on (green) when operating normally. Its absence confirms the battery is in a protection/standby mode due to the fault.Power Cycle Sequence:Turn off the battery using the On/Off button. Wait 30–60 seconds. Turn off the inverter completely (AC and DC isolators). Turn the battery on first, wait for it to boot.Then turn the inverter back on.Hope this helps.
June 15, 20251 yr On the Sun Batt 5.32 battery that fault is Number 12Don't know if it is different on the 10kwSUN_Batt 5.32 LED Indication.pdf Edited June 15, 20251 yr by Virwat
