DB Board
20 minutes ago, Mistral said:
How much should I budget for a DB board installation? (3KW inverter)
R10k+ ... because when they open the board, there is going to be something wrong. I swear. Have THAT T-shirt now too. Earthing was a problem.
Flip side, if all is fine, in-out-CoC in hand, between R2500 and R3500 - depending on the hourly rate.
Edited by Guest
In my experience, I have always found a reason for wishing the big one I installed was even bigger.
I think that is most peoples' opinion.
So if it's a new DB, go big, and then add a bit more space.
12 hours ago, Fazil said:
we always start with a 18 way as the price difference between 18 and 12 isnt that much considering the capacity to expand later.
This and add plenty of spare coduit pipes up to the ceiling ,
18 hours ago, phil.g00 said:
At least twice as big as the size that you think that could contain everything you will need
agree. When I build my house 4 years ago I thought the 60 way (3 x 20) Samite board would be more than big enough. It is already to small☹️
In addition to size the design (as I have learned the hard way) is also very important. To remove the frame of my Samite board is such a disaster that I have nightmares about it.
On 2019/04/03 at 10:41 AM, Mistral said:
Any recommendations on design?
depends on the loads but typically we use:
2x 20A for plugs
1x 10A for lights
1 40A mains breaker
as a standard i run a dinrail mount 30A contactor in the db to switch to these priority loads for solar.  that is just me :)
Cost for all the above we supply pre-wired for R3500.   Have supplied plenty already across Josie.
Edited by Fazil
