My VM III Twin 4K (Firmware 60.10) doesn’t read SOC accurately with RES-5WS LiFePO4. Help!"*
On 2025/07/19 at 8:00 AM, thamer said:
RES-5WS LiFePO4.
I'm not familiar with that battery.
All I can suggest is later display firmware; that's what talks to the battery BMS.
What is your display/comms (U2) firmware version?
All I can tell you is that I have no firmware, display or main, later than the ones you already have.
I have not had the time to study the BMS protocol part of display firmwares in any great detail.
How much is the difference between the battery and the inverter readings?
I think it is a calibration issue of volt reading. I have the same thing. My inverter reads 0.3 volts less than the battery, so the inverter application always shows 1% less SOC compared to the BMS.
  • 4 months later...
