April 6, 20197 yr Hi everyone Given how new leoch batteries seem to be would it be correct to assume that Axpert ICC software doesn't yet handle soc monitoring like it can with pylons? And then assuming the above is correct, would a BMV do the trick?
April 8, 20197 yr 1 hour ago, miles said: Probably not to both questions? Leoch has it's own BMS which is compatible with Axpert inverters.
April 9, 20197 yr 6 hours ago, SilverNodashi said: Leoch has it's own BMS which is compatible with Axpert inverters. Compatible in what sense? Does the Axpert actually talk to it at all? If so, how?
April 9, 20197 yr 8 hours ago, Coulomb said: Compatible in what sense? Does the Axpert actually talk to it at all? If so, how? I don't know. They just listed that it's compatible. I suspect the BMS will tell the Axpert what it's SOC and DOD values are?
April 9, 20197 yr Author Done a bit more research and if it's compatible in the same way as the Pylontech (ie not really) then not really. The ICC chaps are working on a cable and integration similar to what they've done with the Pylons though. So there is hope.
