Up and running...
54 minutes ago, JTK said:
with the limit. will it still feed excess MPPT to the primary load side? Or will this also top out at the limit value?
It will top-out at the limit. That is unfortunate... but this stuff is already so complex I don't want to even go there 🙂
If you don't have a prepaid meter that causes issues, you can always turn on "feed excess solarpower to grid", then it removes all limits and feeds all excess to the loads or the grid.
  • Replies 52
  • Views 10.5k
  • Let me tell you the whole long tale. So first off, what is the purpose of scheduled charging? Scheduled charging is for people with a TOU tariff, that is time of use. Power is literally so expens
  • So if I read this correctly, if you set the 'Optimised with Battery Life' and set the charging schedule to charge from 10:00 to 00:00 and a SOC of 80% then it will use the batteries from 00:00 until i
  • If there is a grid failure, then the inverter switches to backup mode and none of the charge/discharge limits or scheduled charging stuff applies. Even discharge limits on the battery will be ignored
done. I just wanted my ET112 to see the net effect... ;)
