Microinverter & Panels to Aux Input on Sunsynk
I have read enough to know this is possible and spoken to two installers who are looking into this.
Setup so far:
8.8Kw Sunsynk
16 X 550W Longi
6 X R100 5.2Kw Revov
Now I wish to add a 2500W Microinverter to the Aux Input and face 4 X 615W panels to the rising sun early morning to feed into the system so that the morning draw does not deplete the batteries.
If you have done this and can offer advice as to where to purchase the needed Microinverter I would appreciate that.
Setup so far:
8.8Kw Sunsynk
16 X 550W Longi
This is a easy add on. As the Solis 4G mini is such a reliable inverter I would look at sites selling them 2nd hand. Price will be around R3000. Start up voltage is around 120V iirc. No need for a CT to prevent export as the Sunsynk will control the export.
I haven't done it personally, but know of people that have. Give Wimpie (Powerforum-store) a call or WhatApp on +27 67 189 7084, he has oodles of experience, gives great advice and has sourced specific things for me in the past at a great price.
9 hours ago, Scorp007 said:
Solis 4G mini
It's not a must, but it is nice to have an inverter that responds to frequency shift. I also prefer not having the electronics sitting between the roof and solar panels.
I'm curious about this setup of a micro inverter to the aux in port. I know it is tied to the battery charge state when to kick in and off but what I would like to get more info on is how the power is split.
E.G. on a 5kw Sunsynk on a sunny day the sunsynk hits its max 6500w and the micro can hit say 2300w (I understand you should not exceed 50% of the inverter size) will the system then utilize the full 8800w splitting the micro to the batteries (2300(micro)+2800(ss)=5000w Max charge rate on battery from DC) and the 3700w goes to load or is it going to still throttle down to the inverter max input of 6500w for the combined input? I know the home load side has about a 5500w limit on draw but that is on the load side so I do get you will not be able to exceed that. My shortfall is in the winter when overcast as the batteries cant reach 100% so just exploring options that will be most cost effective besides just using grid to top up when really needed.
