April 26, 20197 yr if the installer used the recommended mounting structures and is trained, then "should" not be an issue regardless of the roof type. Biggest risk i have seen is for flat concrete roofs so make sure the installer knows his game and uses the best stuff available.
April 26, 20197 yr 21 hours ago, Mistral said: I am wondering how easy is it to remove panels if you need to fix roof leaks? As easy as it was to install, just in reverse
April 26, 20197 yr 23 hours ago, Mistral said: I am wondering how easy is it to remove panels if you need to fix roof leaks? Told my installer to make sure there is no leaks, he actually went up and fixed a few loose tiles which not in the path or under the PV panels But lets wait for a Rainy day Edited April 26, 20197 yr by Treschen
