Maxmax2 Posted February 23, 2020 Share Posted February 23, 2020 Thank you. I will email them. Quote Link to comment Share on other sites More sharing options...
Bobster. Posted February 23, 2020 Author Share Posted February 23, 2020 18 hours ago, Fuenkli said: I just had a look at my SEMS station (see below). I am not sure why SEMS looks different when it displays your station. Maybe other Goodwe users can check ( @Bobster?). You can also consider contacting Goodwe support to get to the bottom of this. . In the browser I've always had the display that you show, and I don't see any options for suppressing or defaulting the devices/energy flow tab. Using the app on the phone I get a diagram similar to the energy flow in the browser, plus some "headline" figures and a chart of PV generation for the day. And some other stuff (equivalent trees planted blah blah) if I scroll a bit. The 5 trace graph is available to me if I tap a button. Whenever I run into these sorts of problems, in browser or in app, I always clear cache first and see if that resolves the problem. Quote Link to comment Share on other sites More sharing options...
Maxmax2 Posted February 23, 2020 Share Posted February 23, 2020 Thanks @Bobster. I used to get that display, but now I get the display I posted above. On my app I get the following (2 pictures to show when scrolled), no diagram at all. I will clear the caches in both browser and app and see if this helps. Quote Link to comment Share on other sites More sharing options...
Maxmax2 Posted February 23, 2020 Share Posted February 23, 2020 Nope, still the same on both PC and app after clearing cache. I must say that it doesn't matter if I use Chrome, Edge or Internet Explorer, the view is the same. I have emailed [email protected] as suggested by @Fuenkli, so I will see what this brings. Quote Link to comment Share on other sites More sharing options...
Bobster. Posted February 23, 2020 Author Share Posted February 23, 2020 2 hours ago, Maxmax2 said: Nope, still the same on both PC and app after clearing cache. I must say that it doesn't matter if I use Chrome, Edge or Internet Explorer, the view is the same. I have emailed [email protected] as suggested by @Fuenkli, so I will see what this brings. It's very odd. You are missing the same view in app and in browser, but clearly the portal is receiving data from your system. Quote Link to comment Share on other sites More sharing options...
Bobster. Posted February 24, 2020 Author Share Posted February 24, 2020 On 2020/02/22 at 9:52 AM, Maxmax2 said: I no longer get the flow diagram on SEMS Portal, as in Sparkles quote above, just a screen with a big blue circle showing Generation for the day and other relevant info on both sides of the circle as below, and it is the same on the Android app. Is there any way to get the flow diagram back? Smack the cow and paint the barn red! I got this - the missing devices/energy flow tab - this morning. What I found was that it was a sizing issue. For some reason the page contents were too big for the browser window and so the tab was hidden. OK... having a brand new lap top and monitor might have something to do with it. Anyhoo... I zoomed out (ctrl -) and there they were. Fuenkli 1 Quote Link to comment Share on other sites More sharing options...
Maxmax2 Posted February 24, 2020 Share Posted February 24, 2020 Perfect. Thank you. I am away from my PC for a few days with just my phone. I will give that a bash as soon as I get back. Quote Link to comment Share on other sites More sharing options...
Bobster. Posted February 25, 2020 Author Share Posted February 25, 2020 I'll add that I found the goodwe apps don't adapt well to different android phones. EZ manage works fine on my Huawei (though I don't trust the numbers), but the setup menu for changing operation mode is very crowded on my wife's LG. But PV Master works flawlessly on the LG, is hit and miss on the Huawei. My installer told me that in their opinion the apps only work reliably and accurately on iPhone, but if you are using android, and if you have access to a different model of android phone, you might try installing the apps on that. Fuenkli 1 Quote Link to comment Share on other sites More sharing options...
Maxmax2 Posted February 26, 2020 Share Posted February 26, 2020 I'm back at my PC, and tried to zoom out (all the way to 25%) with no luck. Still the screen with a big blue circle, and no other tabs. I get the same no matter which PC I use or which browser I use, and as I say, also on the app. They all used to display just fine. Quote Link to comment Share on other sites More sharing options...
Maxmax2 Posted February 27, 2020 Share Posted February 27, 2020 Well, after emailing David Havenga, I got a very prompt response, which sorted my problem out. I had changed my classification from "Battery Storage" to "Residential". Apparently Residential is Residential Grid-tie. I hope someone else can use this information, either now or in the future. Fuenkli and Youda 2 Quote Link to comment Share on other sites More sharing options...
Maxmax2 Posted March 1, 2020 Share Posted March 1, 2020 You can change it in the settings on the Android app, but you probably shouldn't. Quote Link to comment Share on other sites More sharing options...
Maxmax2 Posted March 2, 2020 Share Posted March 2, 2020 No, it is in the settings of the SEMS Portal app. The options are Residential, Battery Storage, Ground-Mounted and Commercial Rooftop.I am not sure what each setting does, but Residential does not give you the flow diagram. Pietpower and Fuenkli 1 1 Quote Link to comment Share on other sites More sharing options...
