ZOL Posted October 5, 2019 Share Posted October 5, 2019 Hi everybody, I am planning to connect an Axpert King 5Kw to a bank of PylonTech batteries. The existing bank consists of 2x US2000 plus units. Question is if it will be possible to add a PylonTech US3000B battery to the bank in parallel and also will it be difficult to get the correct settings for the combination? Any comments or ideas please Quote Link to comment Share on other sites More sharing options...
Dex_ Posted October 5, 2019 Share Posted October 5, 2019 according to pylontech they can be mixed yes Quote Link to comment Share on other sites More sharing options...
ZOL Posted October 6, 2019 Author Share Posted October 6, 2019 13 hours ago, Dex_ said: according to pylontech they can be mixed yes Thanks Dex, I assume that it will be relatively easy to set the inverter up in accordance with the combined amp ratings. Quote Link to comment Share on other sites More sharing options...
Dex_ Posted October 6, 2019 Share Posted October 6, 2019 2 hours ago, ZOL said: Thanks Dex, I assume that it will be relatively easy to set the inverter up in accordance with the combined amp ratings. Yep Quote Link to comment Share on other sites More sharing options...
ZOL Posted October 6, 2019 Author Share Posted October 6, 2019 Thanks! Quote Link to comment Share on other sites More sharing options...
SYC Posted October 6, 2019 Share Posted October 6, 2019 US3000 should be installed as the master/first battery Dex_ 1 Quote Link to comment Share on other sites More sharing options...
Dex_ Posted October 7, 2019 Share Posted October 7, 2019 8 hours ago, sulyc said: US3000 should be installed as the master/first battery you seem to have his exact requirement as your system, what is your amp charge setting 2? Quote Link to comment Share on other sites More sharing options...
SYC Posted October 7, 2019 Share Posted October 7, 2019 25 amp per Pylon Quote Link to comment Share on other sites More sharing options...
ZOL Posted October 7, 2019 Author Share Posted October 7, 2019 How will the US3000 as master and the 2x US2000’s get charged in sync? The US3000 needs more amps to get charged simultaneously with the US2000’s? Will the system split the feed in proportion to the capacities or will it take longer to charge the US3000? 1 hour ago, sulyc said: 25 amp per Pylon Quote Link to comment Share on other sites More sharing options...
SYC Posted October 8, 2019 Share Posted October 8, 2019 You need to set at 75 amp coz you have 3 pylons and the built in BMS sorts charge sync and distribution accordingly. They all charge simultaneously. Quote Link to comment Share on other sites More sharing options...
