andrew9484 Posted November 28, 2019 Posted November 28, 2019 Hi All, interested to hear your experience if you are using Bluenova Lithium cells (especially if you have used for considerable time). I have had bad experiences with AGM cells and then VRLA cells. i am considering going to Bluenova in the hopes that it will be a reliable solution for a long time. Any comments would be appreciated. Quote
Fazil Posted November 28, 2019 Posted November 28, 2019 why this specific brand? I am not shooting the brand down as they are awesome batteries. do some research on other brands like Freedom Won, SMD, Soltaro, Pylontec, Dyness etc Quote
___ Posted November 28, 2019 Posted November 28, 2019 (edited) 1 hour ago, Fazil said: why this specific brand? One reason might be because you have a specific preference for LiFeYPO4 cells (Ytrium, has a temperature advantage, or so they say). BlueNova uses Winston cells, which is a more expensive kind of cell, but it has the Ytrium component. That might be one reason. We can debate whether it really matters... I personally don't know. Edited November 28, 2019 by plonkster Quote
NigelL Posted November 28, 2019 Posted November 28, 2019 (edited) Hi Andrew I have had the BlueNova BN52V-230-12k (52V 230Ah 12kWh) for just over 1 year and am very happy with it. The guys at BlueNova have also been very helpful with the odd technical question. The main point to note is that the internal BMS is not very accurate at measuring low discharge currents - so you need to include a BMV712 (or similar) to accurately measure current into/out-of the battery so that you have a realistic idea of the SOC. Edit: BlueNova is now part of the Reutech group, so have significant backing, which is useful for a product that has to have long-term support and warrantee. Edited November 28, 2019 by NigelL Quote
PJJ Posted November 28, 2019 Posted November 28, 2019 1 hour ago, plonkster said: but it has the Ytrium component. From what I have read it seems that its only useful if you live in a very cold climate where using the cells would otherwise damage them. ___ 1 Quote
andrew9484 Posted November 28, 2019 Author Posted November 28, 2019 4 hours ago, Fazil said: why this specific brand? I am not shooting the brand down as they are awesome batteries. do some research on other brands like Freedom Won, SMD, Soltaro, Pylontec, Dyness etc what i like is the fact that they are local. in my mind this will help for support and also warranty repair transport costs (should it be necessary) Quote
andrew9484 Posted November 28, 2019 Author Posted November 28, 2019 2 hours ago, NigelL said: Hi Andrew I have had the BlueNova BN52V-230-12k (52V 230Ah 12kWh) for just over 1 year and am very happy with it. The guys at BlueNova have also been very helpful with the odd technical question. The main point to note is that the internal BMS is not very accurate at measuring low discharge currents - so you need to include a BMV712 (or similar) to accurately measure current into/out-of the battery so that you have a realistic idea of the SOC. Edit: BlueNova is now part of the Reutech group, so have significant backing, which is useful for a product that has to have long-term support and warrantee. i already have a BMV712 so that is not an issue Quote
Fazil Posted November 28, 2019 Posted November 28, 2019 3 hours ago, andrew9484 said: what i like is the fact that they are local. in my mind this will help for support and also warranty repair transport costs (should it be necessary) Freedom Won is local Solar MD is local Both have great support. Quote
___ Posted November 29, 2019 Posted November 29, 2019 (edited) 13 hours ago, Fazil said: Freedom Won From what I read yesterday, the Sinopoly cells used by FreedomWon are in fact very good quality cells, except that they lost the right to the Winston formula when the companies split. Or something like that. So no Yttrium for them. I think the FreedomWon battery has the better BMS, but the BlueNova battery has the better cells. My opinion anyway. I like the white powder-coated package of the FreedomWon battery a LOT! Edited November 29, 2019 by plonkster Fazil 1 Quote
PaBz0r Posted November 29, 2019 Posted November 29, 2019 3 hours ago, plonkster said: white powder-coated package of the FreedomWon battery I also like the look, but damn the actual size gets crazy! ___ 1 Quote
