December 15, 20196 yr A couple of months ago I replaced the USB module on my Axpert inverter with their Wifi module. WIth factory options you connect directly to the box and set up you WiFi password, etc. Unfortunately I got this wrong so it isn't connecting to my WiFi and I have no way to connect to it. The documentation (see attached) tells you how to perform a factory reset by using a jumper on the board - the 2 problems with this are: 1) they don's supply a jumper thingy - I guess I you just use piece of wire//paper clip? 2) the described board differs from the actual board (see attached) and I have no idea which pins to connect? I have not been successful at finding a solution with Google so would be grateful if anyone has any ideas as to how I can get back to the WiFi factory settings. Thanks PastedGraphic-2.tiff PastedGraphic-1.tiff Edited December 15, 20196 yr by gavgold
December 16, 20196 yr 12 hours ago, gavgold said: Unfortunately I got this wrong so it isn't connecting to my WiFi Err, I don't believe that the card supplied is WiFi at all. In fact, I don't believe that any models with the "Axpert" name have a suitable slot for a WiFi card. Per this post, the card in the first photo is a 2014 ordinary RS-232 card. Did you send the wrong photo? What exact model Axpert do you have?
December 16, 20196 yr Author No, that's the correct image. The RS-232 goes to an external box which is WiFi. This post has an image wifi box
December 17, 20196 yr 5 hours ago, gavgold said: The RS-232 goes to an external box which is WiFi. Then to reset the WiFi, you have to do something to that external box, not to the communications board. Perhaps try to find information about that external box.
December 17, 20196 yr https://voltronicpower.com/en-US/Product/Detail/Wifi-Card#tab_menu1 The above link has an option to download the manual after registering with Voltronic. Hopefully the link works and the manual will have the method of resetting the box to default. Otherwise examine the box for a small button (often close to where the power plugs in) or a pinhole into which you can insert a unbent paperclip. Depress the button, or insert the paper clip and press against the resistance you feel (internal button),for 10 seconds whilst the power is ON.
December 17, 20196 yr Author Thanks @Thunderdolt - now i know who to contact if i don’t come right. 8 appreciate the help.
