Victron Battery monitor BMV 700
  • Replies 64
  • Views 13.8k
  • Thank you, R1000 onco I managed to get the 702 cheap and did not use the 700
  • Chris Hobson
    Chris Hobson
    I'll keep that in mind Camel I will need a 702 in 2017.
  • Chris Hobson
    Chris Hobson
    I still like Ed's solution a CP2102 for 50 bucks and you do not connect the power lead you just connect RX,TX and GND. I bought this which reckons it is isolated but since it can work without pow
7 hours ago, Camel said:
Thanks Mark will keep that one in mind.
Let me support local firstB)
Thanks jdp, I have come this far but suck now....... I am not the cleverest when it comes to software......:mellow:
Camel,
Your COM port is in use by something else. Do you have other available com ports?
Yep the port is in use. Do you have Watchpower running? You need to close it down. Also the console app should not run. I have left certain exceptions unhandled so that you can see the full stack trace.
Hi Guys,
Sorry been man down with flu, I have not come right yet and with having the flu i could not care right now!
Anyone willing to teamview in for me while i sleep and fix it...................:D
Still have 2 cables left if anyone is looking for them. Will be in JHB next week if you want face to face delivery :P
17 hours ago, Camel said:
Hi Guys,
Sure! PM me when you are available and i can have a look.
Ok laptop ready to be Teamviewed, who can help I did PM Valken but he might be busy.....................:)
I can have a look. PM me the details
I did try to connect but you don't seem to be on line..
Are you sorted?
Sent from my SM-G920F using Tapatalk
I help Camel but he does not have a converter and AICC is only serial at this stage.
  • 5 months later...
