March 15, 20206 yr The Shoto SDA10-4850 50AH lithium battery has a row of connectors on the front panel for digital outputs. I am trying to find out what they are. Googling this has been unsuccessful. And, does anyone know who the local distributors for Shoto are ?
March 20, 20206 yr Hi you may contact Current Automation/Rectifier in Kya Sands. I’ve seen Shotos in their place. Regards.
June 3, 20206 yr Apparently Growatt have now completed the communcation protocol for Shoto batteries. Anyone else aware of this ?
June 5, 20206 yr Hi all Who can assist me with the battery settings for the Shoto 100ah Lithium for the kodac King inverter 5kva. The system is backup only for now. Just installed. When i remove utility, the battary immediatly drops to around 49.5V and my display on inverter shows that battery is half. Is this correct? What is the correct voltage for low voltage cut off to ensure that i do not go over 80% DOD. Thank you in andvance if anyone can assist.
June 6, 20206 yr I have a Growatt inverter and my settings are on SBU I set my bulk and float to around 55v. Back to battery at 52v and back to Grid at 48v. This leaves about 25 percent left in the batteries (there’s 1 led solid). I get close to 6kw from my 2x 4.8 kw m14’s. If I set the back to grid to 47.5, I get a low voltage alarm. At least I’m getting about 65 percent of the intended capacity with this. The BMS Cable and protocol is imminent but long overdue from shoto
June 6, 20206 yr Hi Anish When you switch to battery from what voltage does the discharge start? My float is 53.7v and immediately drops to 49.7v.
June 6, 20206 yr Mine drops to about 50v too. I’m not an engineer but I suspect that it has to do with the non linear (flat portion) of the battery discharge curve of a lifepo4 battery. I’m getting the batteries to ‘near full’ on the Shotos led SOC indicator. The inverter reads them completely differently. There’s often a disparity between what the inverter sees and the actual SOC on the battery. Notwithstanding , I’m getting about 60 odd percent out of them using voltage parameters only. Edited June 6, 20206 yr by Anish
February 27, 20233 yr I am at wits end with Shoto product. When I buy a Mercedes and drive to Cape town, for any problem I can visit any Mercedes Branch. With every dick tom and harry now installing solar, the first question you are asked " Did you buy it from us ?" If not, sorry can't help you. I sincerely hope the industry just dies ! Where can I take my Shoto Battery that is still under warranty for repairs ? My Installer is a fly by nighter, so no hope there. Any help will be appreciated.
October 27, 20232 yr On 2023/02/27 at 2:13 PM, Silvester said: I am at wits end with Shoto product. When I buy a Mercedes and drive to Cape town, for any problem I can visit any Mercedes Branch. With every dick tom and harry now installing solar, the first question you are asked " Did you buy it from us ?" If not, sorry can't help you. I sincerely hope the industry just dies ! Where can I take my Shoto Battery that is still under warranty for repairs ? My Installer is a fly by nighter, so no hope there. Any help will be appreciated. You didn't buy a Mercedes. You bought a Shoto.
