April 4, 20206 yr Good Day All Some advice will be appreciated. I am aware the my Axpert King inverter does not communicate with the batteries. Thus the SOC shown on the inverter and the actual SOC of the batteries are not the same. I've got 3 Narada batteries and the have 4 SOC light indicators on the light 1 = 0-25% light 2 = 25-50% light 3 =50-75% light 4 = 75-100% we have had non stop cloud for the last 3 day and i've noticed the following. According to the inverter the battery voltage drops to 45V and the system then switches over to ESKOM, although there are still 3 lights illumined on the batteries meaning minimum 50% SOC available on the batteries. So here is the question: Except for getting the official narada comms cable to communicate with the ICC on the Raspberry PI. is there another way to force the inverter to use the use battery power that is still available? Hope this explanation makes sence. Looking forward to the replies. Greetings Albert
April 12, 20206 yr Hi all, I bought the Growatt inverter with Narada batteries. Same question. Haven't had much luck with comms yet. Narada gave some information, but in Chinese. Haven't had luck yet. Growatt - some emails, no information. E
April 12, 20206 yr From the Narada datasheet, at maximum rated discharge current, 45V corresponds to around 90% discharged... They do not give temperature derating curves, so I do not know what the range on that would be. But still it would seem that something is not entirely right. Have you measured the real battery voltage and checked the battery cables?
April 13, 20206 yr 8 hours ago, JustinSchoeman said: Have you measured the real battery voltage Yes. It's possible that the inverter's battery voltage calibration is off. It is possible to send commands to correct it, see this post.
October 26, 20214 yr I have recently purchased the ICM-PI Complete kit (Licensed) Raspberry Pi 4 from Intelligent Customised Coding (ICC) and 2x Narada Iron lithium Phosphate 48NPFC150 (Battery Module for Telecom). i also bought the communication cable between Narada batteries and Raspberry Pi, and cannot get the batteries to connect to the Raspberry PI. I need a subject matter expert to assist in this regard
