April 19, 20206 yr Hi i would like to get some advice on solar panel power , I have two inverters , grid tie inverter and a off grid inverter , i will put 18 panels x 330w to my grid tie inverter , my off grid has no panels at this moment , I have a victron charge control for future panel installation of panels for off grid inverter , what i need to find out is it possible to change over my solar panels from my grid tie inverter to my off grid inverter when there is no city power , If someone can recommend which change over switch or which contactors I can use to change the solar panels from grid tie inverter to off grid inverter when there is load shedding , please advice if possible thanks
April 19, 20206 yr There are inverters that will do both these functions. Did you buy the wrong inverter for your needs?
April 20, 20206 yr Hi Kiranbhowan You need a DC contactor or a DC change over switch - both of which are more expensive than their AC counterparts. There is usually a magnet which deflects the ensuing spark when switched into a catch cage. ABB make a DC rated contactor. If you cannot get a DC contactor you can make a very good snuffing circuit by placing a large enough capacitor across the terminals of the contactor. While the contactor is closed the potential difference across the terminals is zero. As the contactor opens there is a potential difference and the capacitor starts charging. I am not sure your local authority would accept a contactor/capacitor combination. Your capacitor needs to have a voltage rating higher than your PV strings. There are some good videos on Youtube. Here is one. I cannot find the one I was looking for. This pommie's demonstration is good but health and safety would have a field day 😁 Edited April 20, 20206 yr by Chris Hobson
April 21, 20206 yr 19 hours ago, Chris Hobson said: This pommie's demonstration is good but health and safety would have a field day 😁 Now that’s what you call a “real” sparky, 😂
April 22, 20206 yr Good morning . I am running aMercer sol-I-ax-5p hybrid inverter with 6 energia panels polycrystalline and 2 PYlontech lithium iron batteries US3000.I am running the following program settings Program1: SBU2: 60A3 and 4, leave as default5: select USER for battery type6 to 9, leave as default11: 60A12: 48V13: 51V16: SNU18 to 22, on default.23: BYE25: default.26: 53.2V27: Default29: 47.5V31 to 38 on default. I have this error appearing on the photo attached . The fault light is flickering. May you kindly assist Attachments image.jpg 915.3 KBViews: 14
