May 31, 20206 yr morning anyone with a knowledge of how to wire this with the inverter. my electrcian not familiar with solar energy. i bought this with Mecer 5kw plus and 5000w of panels, battery fuse and ICC. Everything working except this is not yet connected. any ideas or drawings to help me
May 31, 20206 yr 1 hour ago, BronCo said: any ideas or drawings to help me I would wire it like this, it will allow you to completely and safely isolate and bypass the inverter in the event of an Inverter failure. Bypass.pdf
May 31, 20206 yr 13 hours ago, Jaco de Jongh said: I would wire it like this, it will allow you to completely and safely isolate and bypass the inverter in the event of an Inverter failure. Bypass.pdf 492.2 kB · 9 downloads That's perfect
June 3, 20206 yr Author hi jaco it works 99% The only problem is when i try to bypass the inverter using the position II on the changeover (labelled BYPASS on the pictures that i attached) the mains trips. any idea why? BroncO
June 3, 20206 yr Author No, not in this Box , but from main DB (it's earth leakage that actually trips), i have 2 DBs , one for essential and the other for non essential, they DON'T share any neutrals Bronco
