August 11, 20206 yr Just commissioned my Easysolar GX II on Monday with two 2.4 Pylontech’s and eight 355 watt Canadian Solar panels, system working great, a huge thanks to Jaco for supplying the Easysolar II and it so happened that he was in Cape Town for a couple of installations and graciously offered to help commmision the system, which I would have spent days, also, cannot forget Plonkster’s help ps: the WiFi setup on the Easysolar solar is basically non existent,so plan on running an eathernet cable to your router or use the WiFi dongle Tariq
September 18, 20205 yr Hi Tariq, Agreed the EasySolar II WiFi is non existent, I’m in the WiFi business and gave up on this WiFi, RJ-45 cable is the way. I pulled 2 x RJ-45’s as my install is located in the garage, the 2nd cable is used for the Victron energy meter located in my main DB.
