Dirty PV panels
Now that I have been online to pvoutput.org for a week and being a bit ocd about the live feed power outputs I felt that my peak output was not where it was last year. This evening I climbed up onto the shop roof to look at the state of my power station. Eish. Thanks to the drought here they are truly dusty and dirty as they have not been cleaned since installation 9 months ago.
45 of them is quite a mission so will do 6 each evening. Intrigued to see the difference.
I had same. the last fires in CPT, I saw a reduction in production. After washing the panels, problem was solved.
A long handled glass washer (sqeegee) works well unless something really ingrained - Should be done every 3-6 months unless you really fanatical.
I have a monthly maintenance schedule for checking all sorts of things on a dedicated maintenance day (3rd Sunday each month), my panel cleaning, battery testing, terminal checking and greasing +++ is all on that list. That way even if you find a repair takes you longer than the day, you'll get to the other regular stuff next month and at least every 2 months stuff gets checked.
A beautiful sight... I'm dreaming!!
Can you give us some background the the projects and reasons for installation/benefits.
Inverter details etc please...
Adding another 15 or so panels shortly. Just wanted to have a year of generation documented as I dont want to produce a negative electricity bill.
He he, from your pic and the background, I now know exactly where you live.:D Never noticed the panels before, will be more observant next up that way...
