August 23, 20206 yr It's 25 and 29 or 39? A slight temperature difference is normal, as heat tends to build in the upper levels while lower levels stay cooler. Therefore, the top bricks are always a degree or two warmer than the bottom ones. Temperature 25° vs 29° is okay, I'm seeing a similar difference in my lab. On the other hand if that's 25 vs 39 on that picture, then it's way too much and something bad is happening.
August 23, 20206 yr 2 hours ago, Youda said: On the other hand if that's 25 vs 39 on that picture, then it's way too much and something bad is happening. It's 25 and 39 If they are both in the same location, then agree that there is something wrong
