Clint Posted July 18, 2013 Share Posted July 18, 2013 How do you rate the Microcare 10 kw 48 Volt inverter http://www.microcare.co.za/products/inverters5/10kw-48v-pure-sine-wave.html Quote Link to comment Share on other sites More sharing options...
Mike Posted July 18, 2013 Share Posted July 18, 2013 for me on a personal note is that i cannot understand why if it's a local product, there is no incentive in terms of price to purchase one as opposed to a Victron. One would expect local to be more competitive in pricing. Clint 1 Quote Link to comment Share on other sites More sharing options...
Wetkit Posted July 19, 2013 Share Posted July 19, 2013 @Clint, why you looking to go so big with the invertor? Just by doing small stuff you can easily limit your max demand to below 5kw. Clint 1 Quote Link to comment Share on other sites More sharing options...
Clint Posted July 19, 2013 Author Share Posted July 19, 2013 Mike the Microcare seems to be better priced http://www.alternagy.co.za/shop/victron-inverter-quattro-4810000/ http://www.alternagy.co.za/shop/microcare-bi-directional-inverter-10kw/ Wetkit you have a good point.The problem I have is when we start cooking we need about 5000 W Maybe changing to gas will help Thanks guys Quote Link to comment Share on other sites More sharing options...
Wetkit Posted July 22, 2013 Share Posted July 22, 2013 Clint, you planning to go totally off-grid? I am just trying to think of the logic of the 10kW unit. You can run your stove, geyser and oven from your solar, but why. It is very easy to either bypass them so they do not run from solar at all. With grid-tied you can go as big or small as your solar panels, the unit can only deliver what the PV panels provide, so it is not connected in series with your existing supply. Quote Link to comment Share on other sites More sharing options...
Clint Posted July 22, 2013 Author Share Posted July 22, 2013 I want to get off the grid completely I am still trying to work out how I can run everything off a 5 KW inverter I have already saved the money for 5000 w panels 10 KW inverter and 8 200 ah 12 V batteries. My theory is that there is no reason why you have to skimp when going off the grid. I also believe using a more powerful inverter will be not work as hard so it should last longer Quote Link to comment Share on other sites More sharing options...
Wetkit Posted July 23, 2013 Share Posted July 23, 2013 You are a very brave man!!! I do hope you have some type of meter on your house at this moment so you can track and record your consumption accurately. Reason I say this is that 200Ah x 48V is not going to last long on even a 5kw invertor, nevermind a 10kw. @ 2kw load you might be able to get 2hours from the battries before they flat. With what you trying to do, the 6kva MLT might work much better. 1. It can combine invertor and mains output, to give you a peak output of 12kva. 2. With the smart load relay option, you will be able to connect and disconnect certain loads depending on your consumption. So while the microwave is on, the stove and kettel will be disconected. 3. Built-in options for backup generator control. For total off-grid application these functions would be essential. Invertor reliability is directly related to the quality of the capacitors. Once those go, it is not worth it to repair. The cooler you can keep the unit, the longer the battries and the invertor will last. Clint 1 Quote Link to comment Share on other sites More sharing options...
Clint Posted July 31, 2013 Author Share Posted July 31, 2013 Wetkit thanks for that info,I plan to use 8 200AH batteries which should give me 19200 watts of power. I do have a back-up generator. My daily consumption is about 12 KWH and I can reduce that a lot My fridge for instance is an auto defrost and it consumes a lot of power. I will look into the MLT drive inverters Quote Link to comment Share on other sites More sharing options...
