Reinhard Posted October 28, 2020 Share Posted October 28, 2020 Hi All, I have a question about this inverter that bugs me. My system consists out of a single Axpert MKSii, a 3.5kW Pylontech battery and 7 x 285W (was 8 panels) panels. I purchased a second hand 1kW generator from a friend and connected it a few days ago. I started it up and decided very quickly that the output voltage of the generator was fluctuating too much for me to consider keeping it there. After that, my wife started complaining that the power is "weak". The next morning, our washing machine did not want to drain. It seems that the pump does not want to work when it has water in the system. we replaced it and the new pump also does not work, only when there is water in, almost as if it is too weak. Also, the refrigerator is making a strange noise and stays on for longer, to such an extent that the battery goes flat, which was not the case in the past Could it be a setting, or did I blow something again? According to the inverter, it produces a constant feed of 230V and does not fluctuate Quote Link to comment Share on other sites More sharing options...
Bloubul7 Posted October 28, 2020 Share Posted October 28, 2020 Have you measured the voltage on any of circuits? Quote Link to comment Share on other sites More sharing options...
Reinhard Posted October 28, 2020 Author Share Posted October 28, 2020 The voltage on the circuits is 230V. It fluctuates by maybe 1 Volt Quote Link to comment Share on other sites More sharing options...
Reinhard Posted October 28, 2020 Author Share Posted October 28, 2020 My wife was also complaining now that her gas oven's fan doesn't come on. Quote Link to comment Share on other sites More sharing options...
Reinhard Posted October 28, 2020 Author Share Posted October 28, 2020 Could it be because suddenly setting 9 is 60Hz? Quote Link to comment Share on other sites More sharing options...
Bloubul7 Posted October 28, 2020 Share Posted October 28, 2020 27 minutes ago, Reinhard said: Could it be because suddenly setting 9 is 60Hz? It doubt it, but would suggest setting it back to 50Hz. Our grid runs at 50Hz Quote Link to comment Share on other sites More sharing options...
Reinhard Posted October 28, 2020 Author Share Posted October 28, 2020 It was the problem. I'm not at home. I explained to my wife how to change the setting and now everything works 100%. Coulomb and Bloubul7 2 Quote Link to comment Share on other sites More sharing options...
Coulomb Posted October 29, 2020 Share Posted October 29, 2020 20 hours ago, Reinhard said: Could it be because suddenly setting 9 is 60Hz? Wow. That generator must have been bad. So bad that the inverter somehow auto-detected 60 Hz. I didn't even realise that it would do that. Good to know, thanks for the report. Quote Link to comment Share on other sites More sharing options...
