DevE Posted February 27, 2021 Posted February 27, 2021 Good Day I have recently installed an Imeon 3.6 inverter and am struggling to find a link for the Imeon Manager software.... would anyone be able to assist? I am connecting via the USB port in the inverter as it is one of the older generations that’s does not have a Wi-Fi module fitted. Any help would be greatly appreciated! Quote
WannabeSolarSparky Posted February 27, 2021 Posted February 27, 2021 Have you tried here:https://www.inutec-int.com/us/inverter/accessories/downloads/ Quote
MyOwnPower Posted September 28, 2022 Posted September 28, 2022 On 2021/02/27 at 9:49 AM, DevE said: Good Day I have recently installed an Imeon 3.6 inverter and am struggling to find a link for the Imeon Manager software.... would anyone be able to assist? I am connecting via the USB port in the inverter as it is one of the older generations that’s does not have a Wi-Fi module fitted. Any help would be greatly appreciated! DevE, Not sure if you managed. I noticed the following that was posted recently. https://support.imeon-energy.com/en/support/solutions/articles/80000602427-how-to-download-obtain-the-imeon-manager-software-fa47- I also have an Imeon at one of my installations, I do have an IMA-Box connected to the Inverter via USB, I can connect to the IMA-Box via WIFI. The Imeon by itself has now remote access only monitoring. However, I got around this by setting up a Dynamic DNS account and activating the DDNS function on my router. As a result I'm now able to log in from anywhere in the world to make setting changes on my Inverter. Hope that helps. Quote
EtienneG Posted October 5, 2022 Posted October 5, 2022 Hey guys, after a long struggle I managed to get the IMEON software and installer codes. (For an IMEON without the IMA box) The software is here: https://imeon-energy.com/wp-content/uploads/support/IMEON _MANAGER_V2.2.2.exe and the installer code can be generated by using this key: https://imeon-energy.com/wp-content/uploads/support/IMEON_KEY.exe Hope this helps someone! E Quote
freierMensch Posted October 9, 2022 Posted October 9, 2022 Hello i am new here, but the Installer code did not work at my computer, it say i have to install Java, but after install it did not work. Any idea? Regards Bernd Quote
GavinS Posted October 12, 2022 Posted October 12, 2022 Hi EtienneG. Thanks for the Imeon Installer Code key, do you know how to enter the "Pro Mode" so that one can enter the generated key. Quote
freierMensch Posted October 15, 2022 Posted October 15, 2022 Hi In the pro mode you would have to click on the button on the top right on "about" and then you click on advanced settings. You have to click on the writing, there is no button. So straight to the writing. Hope you understood me and it works. the Etienne software doesn't work for me maybe you can generate a code and send it to me? LG Quote
GavinS Posted October 15, 2022 Posted October 15, 2022 FreierMensch. I will send the code, please provide your Serial Number. I am running Imeon Manager 2.1.2. I cannot find the "about" word in the text. which version of Imeon Manager are you using? Quote
GavinS Posted October 16, 2022 Posted October 16, 2022 FreierMensch. I have managed to gain access to the Pro Mode. Cursor on Copyright symbol at bottom of Imeon Manager screen, press "Ctrl" on keyboard and right click on Mouse.. Quote
freierMensch Posted October 16, 2022 Posted October 16, 2022 Dear GavinS, I made a mistake, I'm communicating with the Imeon via OS.ONE software via Wireless Internet access. It is very different look from Imeon manager software as you can see in the picture, but it is the same. I will Test the Imeon Manager Software you use again and write back in a few days. I'm also dissatisfied with the OS.ONE software, I can't do what I want there either. I've been struggling with a problem for 4 weeks, the support in France hasn't also been able to solve until now. If I set a SOC Discarge stop of 40 or 50% and the discharge has reached that point, the inverter will charge and discharge simultaneously until morning and the SOC will drop another 8-15% in the process. The problem seems to come from the Water Heater app, which I already disabled in wintertime, but the App remnants seem to be causing it. Stupid thing. I am so sorry that I can´t help you. Regards Quote
DrLoLCat Posted November 28, 2022 Posted November 28, 2022 On 2022/10/15 at 10:09 AM, freierMensch said: Hi In the pro mode you would have to click on the button on the top right on "about" and then you click on advanced settings. You have to click on the writing, there is no button. So straight to the writing. Hope you understood me and it works. the Etienne software doesn't work for me maybe you can generate a code and send it to me? LG @freierMenschwhere is the "about" text that you mention in your post? I'm very interested in the advanced settings. I am already in pro mode. See below. Hi, Quote
freierMensch Posted November 30, 2022 Posted November 30, 2022 Hello Dr.LoLcat, i write before that i make a mistake, because i use other software the OS.One and I say sorry about, Those who can read have a clear advantage But look good the pro mode, respect Regrads Quote
Strauss Posted December 28, 2023 Posted December 28, 2023 How do you enter pro mode imeon key wont open any help Quote
