May 14, 20215 yr Is the pv switch on the inverter an isolater, or do we still need to install an additional isolater? Edited May 14, 20215 yr by Tariq
May 14, 20215 yr 2 hours ago, Tariq said: Is the pv switch on the inverter an isolater, or do we still need to install an additional isolater? It is an isolater, but not a very useful one, does not have many safety benefits. I still had proper external DC isolaters installed, as well as surge protection.
May 14, 20215 yr Author Hi @YellowTapemeasure, in your opinion what is missing, regarding safety features on the pv switch as compared to a db mounted isolator
May 14, 20215 yr 6 minutes ago, Tariq said: Hi @YellowTapemeasure, in your opinion what is missing, regarding safety features on the pv switch as compared to a db mounted isolator I value my fingers. If I want to work on the inverter, or inspect or even poke around it, I can isolate the incoming PV using the DB mounted isolator, disconnecting the battery fuse/isolator and isolate the grid. I don't have to trust the DC isolator on the inverter itself, it's still live DC going into it, which can be very nasty. Maybe I am paranoid?
