Growatt spf5000es not using solar when Utility is on
On 2022/06/05 at 7:55 PM, zsde said:
Could be the Back to Battery or back to utility settings. I am off grid, i.e. no utility connection, so mine is either solar or battery. What are your program code 12 and 13 set to?
Which firmware are you on currently running?
@zsde i am still on 41.02 but trying to upload the new firmware now I got from you. I am struggling, the laptop wont connect with the inverter. Can you maybe give me some tips please,i have disconnected utility,disconnected the loads and inverter is set on SUB but only running from the battery with no loads.
  • Replies 69
  • Views 24.8k
  • For me, the SUB prioritization and energy mixing function only works while the battery is charging (LI Battery from GROWATT model ARK 2.56KW on CAN) . When the battery charge reaches 100% the current
  • Hi the best mode for this offgrid inverter is battery first on setting one. You have to get familiar with pressing those buttons. You hit enter long press to enter settings.
  • @zsde just a update. The drivers was the problem connecting to the inverter. I made contact with Growatt overseas, got the new drivers and problem solved. New firmware installed so hopefully everythin
I struggled as well with the last update.
Run the ISP tool as Administrator.
Place your extracted F030_SK041.06 and F2809_SK040.06 bin files in the root of a USB drive or on the Desktop of the laptop/PC you are using.
I found that if these bin files are in a directory the process never starts.
Ensure that the "Silicon Labs" port shows up in Device Manager after you start the ISP tool but before you select the file to flash and use the allocated COM port.
I don't know how old your Inverter is but no matter what we did on a friend's Growatt that he acquired within the last month, we could not flash it. And I did everything the same way I did on my Growatt from middle of last year. So I am not even sure any more that the ISP toool is still compatible with the latest interface Hardware now used by Growatt.
Best of luck.
Edited by zsde
Best of luck.
@zsde thank I will try that first. Inverter is about 2 years old at the most now. I thought of maybe trying another laptop aswell,maybe this ons for some reason wont connect, but I will let you know how it goes. Thanks
Best of luck.
@zsde just a update. The drivers was the problem connecting to the inverter. I made contact with Growatt overseas, got the new drivers and problem solved. New firmware installed so hopefully everything is working properly now.
What Driver are we talking about here?
Perhaps you can kindly share that Driver if you don't mind. Thank you
On 2022/01/29 at 2:56 PM, zsde said:
The 2 bin files in the mail.
Just be aware of the value changes from V to %.
You are on your own with setting 12 and 13 as neither Growatt nor Hubble in my case have tried to answer that question.
They just assume those settings are Voltages.
Hi, the same problem - my firmware is  040 05 701, 041 05 701. Please send me  newest firmware if there are - may be solved problem to me : [email protected]
I believe your mail service provider does not like attachments.
The following recipient(s) cannot be reached:
      '[email protected]' on 2022/07/07 21:07
            552 5.7.0 message content and attachment content guidelines. la26-20020a170907781a00b0072aeaa1bb5esm4114174ejc.211 - gsmtp
Edited by zsde
I have inserted all the links in a word document and sent that as an attachment to your mail address. Seems this mail at least wasn't rejected by your mail server.
Thank you for all!!! I use the inverter without  battery - I will have to connect small battery only for flashing and will try.
  • 6 months later...
Hi @zsde, do you know the latest firmware of the Growatt SPF 5000 ES?
Depends which edition/batch you have.
Mine is the original which uses the 40 series Firmware. The last according to my records were 040.06 and 041.06 which I have on my Inverter.
The later Inverters have 60 series Firmware.
Never cross flash the incorrect firmware. Check with Growatt on the firmware for the later Inverter batches.
Mine are running on 40 04 301 and 41 04 301 and are running to my satisfaction.
Edited by Antonio de Sa
  • 3 months later...
Hi All, have an es5000 growatt, shows solar coming in but whichever setting i put inverter on SUB, SBU or Solar only it does not use the solar.
also looking for the Shinebus app to do the firmware upgrade but not able to find it.
  • 9 months later...
On 2022/06/05 at 7:47 PM, zsde said:
Normally when you select Li in Program code 05 the invertter will jump to program code 36 where you then select a Protocol. In my case with the Hubble it is Protocol 52 and 52 is also used for Pylontech. Also check the pinouts for the CAN connection on the inverter and Battery side. You may have to make up a cable to ensure the Pinouts both sides are correct else it will not be able to communicate with the BMS.
https://www.freedomwon.co.za/wp-content/uploads/Freedom-Won-eTower-Installation-Manual.pdf
So you will need to make up a cable or have someone make it for you. In this case it is Pin 4 to Pin 4 and Pin 5 to Pin5.  That should ensure the comms between Inverter and the battery
You can contact these people to get the correct Protocol to choose for your battery
The International Rep for Growatt in China is Amos Yang and he is on Whatsapp
+86 132 6718 9226
And their local representative is  Nhlanhla  067 172 2120
[email protected]
Do u have the correct email address for Nhlanhla as that email address doesn't exist or his whatsapp number?
  • 3 months later...
We have a growatt SPF 6000. Program 01 "SOL". Everything works great, except at night when the battery goes below 50% the grid comes in which is fine, however when the battery reaches 100% soc then the inverter faults on code 03. My supplier changed the battery but no luck. Is there a way to set the inverter to stop charging at 100% or even 99%. Like I mentioned everything else works great
  • 4 months later...
