June 27, 20215 yr Hi Folks, Can I have the updated firmware for my Axpert VM II 5KVA, noting that my watch power showing Main CPU: 00020.05 and secondary CPU: 00000.00
June 28, 20215 yr 17 hours ago, Getskay said: Can I have the updated firmware for my Axpert VM II 5KVA The only VM II firmware that I know of is the one on this very forum (it took a bit of searching to find it): The file name is VMII 5K_3K MAIN_V2043.rar, but it fact it contains 20.44 (as reported by the QVFW command). There is mention of Inverex, which sometimes have unusual power ratings (e.g. 5200 VA instead of 5000 VA), but this one seems normal. There's a slight risk that it won't work, then you'd be stuck, and would have a genuine reason to plead from your supplier for the latest update 🥺. The above says 180 downloads and three thanks/likes, so presumably some people have tried it. It appears to be about 7 months later (June versus March 2018) than your machine. The same firmware also runs 3 kVA models; the firmware tests the voltage at some pins at startup to decide which model it's running on.
July 6, 20215 yr Author many thanks Coulomb, the manual showing different picture than mine, my inverter pictured below, and to update that secondary version is 00002.03 Edited July 6, 20215 yr by Getskay
July 7, 20215 yr 8 hours ago, Getskay said: and to update that secondary version is 00002.03 I wonder what that is. On your model, there is no removable display, and no separate Solar Charge Controller. I don't think there is a Bluetooth or WiFi processor. Firmware 20.44 doesn't even have a QVFW2 command, let alone QVFW3 which I thought was the source for the "secondary version" in Watchpower. But glad to hear that the firmware is updated and working.
July 26, 20224 yr Hi @Coulomb What are the steps to update the software of VMII? Because the inverter charger does not work well Thanks in advance. Edited July 26, 20224 yr by taha.alakiele
July 26, 20224 yr 9 hours ago, taha.alakiele said: What are the steps to update the software of VMII? Same as with other models: firmware upload instructions. But first you need a firmware update file, and these are very rare for VM IIs. The latest I have is I believe from 2017. It's in the files section of this forum: It says 1.0.0, and it's in a file that suggests that it's 20.43, but it's version 20.44. May 2017. Edited July 26, 20224 yr by Coulomb Added link, version numbers.
July 26, 20224 yr Hi @Coulomb I trying all ports and all of it failed using reflash tool . and watchpower connected but don't have any options for update Edited July 26, 20224 yr by taha.alakiele
July 27, 20224 yr Is the inverter you're trying to update perhaps a clone? There are a lot of VM II clones about at present. Some clones don't have a bootstrap loader, which would cause an error during attempted firmware reflash. I don't know if it would be the specific error that you see.
July 27, 20224 yr Hi Coulomb, Thank you very much for your help Watch power connected as well and read all parameters but don't have any options for update the firmware How can I show the update options in watch power? Is there any way to show the options?
July 28, 20224 yr 16 hours ago, taha.alakiele said: How can I show the update options in watch power? There are no update options in Watchpower. You have to use the reflash tool and USB to RS-232 adapter, or on some models you can update the main firmware via a USB stick (thumb drive) and OTG cable. But not older models like the VM II. I think the only possibility to find out if your machine is capable of being reflashed at all may be the undocumented QBOOT command. It seems to return 1 if the inverter can be reflashed, and 0 otherwise. But sending commands like that is a bit complex. All the required details are in the PIP-4048MS etc topic, if you want to have a go. It's not a 5 step process that I can describe here.
August 8, 20224 yr On 2022/07/26 at 4:43 PM, Coulomb said: Same as with other models: firmware upload instructions. But first you need a firmware update file, and these are very rare for VM IIs. The latest I have is I believe from 2017. It's in the files section of this forum: It says 1.0.0, and it's in a file that suggests that it's 20.43, but it's version 20.44. May 2017. i need 3049
August 8, 20224 yr 1 hour ago, asim said: i need 3049 Good luck. I don't have any 30.xx firmware in my collection.
May 12, 20233 yr NOT TESTED!!, I try to SML II but not accepted. VMII_Ver31.06_reflash_SN92931807100085.7z
May 12, 20233 yr Assuming that it's the same 31.06 that I have [ Edit Dec 2024: it is ], it's for: * For the Axpert VM II. This is not the same as the Axpert MKS II. * Handles 5 kVA and 3 kVA, either PF0.8 or PF1.0. * Also handles 1.5 kVA, PF0.8 only. Edited December 5, 20241 yr by Coulomb
