July 20, 20215 yr Hi, Have an installation that is showing abnormal readings on the solarman app. Sunsynk 8kw inverter. 20xCanadian Solar 420w panels. 4 strings of 5 panels in series. 2 strings connected in parralell on each mppt. 2xHubble AM2 5,5kwh batteries. Production starts of normal and produces 2-3kw then suddenly drops and produces a few hundred watts throughout the rest of the day. Please let me know if anyone has a solution to this.
July 20, 20215 yr Hi What is the state of charge on your batteries? Are you sure that the inverter is giving power to your house? I would guess that the inverter is charging your batteries up to 100% after the night and then bleeding of the power as it has nowhere to go.
July 20, 20215 yr 4 hours ago, thomasf said: Hi, Have an installation that is showing abnormal readings on the solarman app. Sunsynk 8kw inverter. 20xCanadian Solar 420w panels. 4 strings of 5 panels in series. 2 strings connected in parralell on each mppt. 2xHubble AM2 5,5kwh batteries. Production starts of normal and produces 2-3kw then suddenly drops and produces a few hundred watts throughout the rest of the day. Please let me know if anyone has a solution to this. It looks simiilar to mine, my base load varies between 280 and 400W after charging batteries. Tomorrow, do a load of washing, turn the dishwasher on and roast a chicken in the oven. Live a little, then you will see some utilisation 😃 Edited July 20, 20215 yr by YellowTapemeasure
