November 2, 20214 yr On 2021/10/20 at 12:24 PM, Morne SBR said: Last item to arrive Congrats on your setup. Did you get the Cloudlink to work on your Sunsynk 8kw and if so what configuration was used. Also are you able to get inverter and battery data or only battery data?
November 2, 20214 yr On 2021/10/29 at 1:34 PM, Morne SBR said: Very impressed with the set up I am itching for my install to start! Panels delayed by a week now, so must be bit more patient.
November 2, 20214 yr Author 9 hours ago, new2solar said: Congrats on your setup. Did you get the Cloudlink to work on your Sunsynk 8kw and if so what configuration was used. Also are you able to get inverter and battery data or only battery data? They got it to work and do the updates. I have emailed hubble to assist as it won't link on the portal
November 2, 20214 yr Author 2 hours ago, ggza said: I am itching for my install to start! Panels delayed by a week now, so must be bit more patient. I know the feeling.
